what kind of motordyne spacer do I need for 05 auto
what about motordyne
which one ISO THERMAL PLENUM SPACER:confused: can you feel the gains |
You'll need a 1/2" plenum spacer and (for the best result get the) ISO thermal kit. The install takes about 1-2hrs using basic tools.. as for feeling the gains.. it depends.. if you drive like a normal sane person.. then probably not.. the only thing you'll notice is that the car is louder lol..
but yeah there is a 9-15whp gain (Dynapack proven) so you'll be the judge.. but the dyno and 1/4 mile will show you the gain |
what exactly does it do? like technically speaking
https://g35driver.com/forums/intake-exhaust/95091-what-mrev.html
allows your engine to breath easyer at high RPMs |
cool thx
but from what I understood, this only helps out the MT ones |
no thats mrev.. mrev is designed for 05-06 6-speeds
the 1/2" spacer will work with ALL automatics and 03-04 6-speeds |
ah ok
so any downsides or side effects to adding this to a 05AT? |
I have an 05 Auto - 1/2" with ISO thermal Rocks - MREV+ also rocked the car - call and talk to Tony about it - I just did my MREV+ on my Auto - Tony knows the details.
No downside - install on the spacer is about an hour. Rick |
you loose your engien cover
No downside - install on the spacer is about an hour. Rick or mrev plus for auto:confused: |
get the 1/2" spacer with the iso thermal
Originally Posted by 6969g35
which one iso thermal
or mrev plus for auto:confused: Rick |
I just put on the 5/16 spacer, ztube & popcharger on my 05 auto two days ago. I wanted to keep the cover (didn't think losing it was worth 1 to 2 horsepower with the 1/2inch).
The sound, with all three items, is really nice at higher rpms. It's not like your going to smoke the tires now but I'd do it again. |
I would only do the 1/2" with ISO Thermal for Spacer - MREV+ will give you some additional gains....I have extreme mods - and until there are stock dyno's out - I would hold off on MREV+....
Rick |
