Taking the 6MT to the dealer for the first time!
Old Sep 16, 2003 | 07:46 PM
Black2003G's Avatar
The car has 1200 miles and.... i have the both doors rattling, rear speaker deck rattle, headlights are too low, seat heaters arent working properly, driver's seat rocks back and forth, plus any other TSB's that are out on the car. ANything else thats common that i should have them check out!????
Old Sep 16, 2003 | 08:17 PM
redwillow's Avatar
20 Year Member
Re: Taking the 6MT to the dealer for the first time!
you got grease streaks on the windows? pull to the right? or noisy winshield wipers?
might want to remind em about the brake switch recall...
and sugesstion: ride with them and have them verify and acknowledge these rattles BEFORE you leave, otherwise they will just say "customer claims...." ..... "could not verify", even if there is a TSB.
oh, and if you haven't changed the oil yet it might be a good idea. sooner the better IMO.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Sep 16, 2003 | 09:24 PM
redwillow's Avatar
20 Year Member
"Or is this a more serious issue? "
I'm saying exactly what i said before.....
This is a known problem.
There is a TSB for coupes having a constant drift to the right.
Installation of comp rod is the Infiniti solution to this problem.
here it is again for reference.
Service Bulletin Num : 03028 Date of Bulletin: ?
Type: Coupe
Component: FRONT AXLE/SUSPENSION
Summary: Steering Drift to the Right
IF YOU CONFIRM: The vehicle has a tendency for a constant drift to the right on a straight, flat road at highway speeds. NOTE: A vehicle is said to drift, if The vehicle completes a lane change in less than 7 seconds and with no steering correctionfrom the driver and when driving at 60 mph and all four wheels must pass into the other lane during this time (7 seconds) and while driving on a crown-sloped road of less than 1 percent.
ACTIONS: Verify the incident drift as described above. Install the right front suspension compression rod from the Parts Information section of this bulletin.
Old Sep 16, 2003 | 09:54 PM
redwillow's Avatar
20 Year Member
well, then you could always just drive it in reverse. problem solved.
NemesisGee
Aug 11, 2015 07:10 PM
joedaddy1
Jul 28, 2015 02:58 PM
driftsucky
Jul 15, 2015 12:38 PM
