Problem with the Center console Lights
This morning I got in my car and none of the lights for the radio, navi, A/C or seat heater switchs where working.. I small light for the A/c that lets air come in from outside was inguaged and light was on!! but none of the otheres! the guages work with lights and compass and outside temp where on. I checked fuse inside kick panel but all where good and check the roller next to the VDC! ANY HELP?
Tyson
Tyson
what i did find thou was that my ground on my battery was lose from when I replaced it. The terminal is big for the post! but I ghetto'd that for now and it didnt help! Its like the roller switch is bad and stuck off!!! becuase everything else works.
I had just had the same problem, checked the roller and all the stuff you checked. What ended up happening is my wife changed my headlights from auto to a different setting. Changed it back and the lights came back on. Hopefully that is all that has happened
Your dash looks like mine when the Air is off. Try turning on the fan. With the A/C and fan off, all console lights are off except the outside temp and compass.
