benefit of sway bars on sedan w/Sport
Old Sep 19, 2003 | 12:00 PM
SoCalTed's Avatar
Just wondering...what is the benefit of installing sway bars on a sedan that has the Sport suspension?
'03 Sedan 5a: Silver/Graphite, Premium, Aero/Body, Sport, Nav
SolarGard Quant. Tint 19% r, 28% fr, & just a tad more than 4" of 50% on the windshield
Old Sep 19, 2003 | 12:23 PM
Gsedan35's Avatar
Re: benefit of sway bars on sedan w/Sport
Keep in mind that all the G's and the Z all use the same sway bars, same diameter's as well. It is by installing aftermarket 350Z sway bars that you'll come to realize benefits.
Allot less understeer. Allot less body roll. Greater confindence when attempting manuver's that would draw off the bars greater stiffness. Turn in performance is better. Around town, your everyday right and left turns have a much higher fun factor. And if you want to kick the tail out a tad while finishing a corner you can do so and as your cornering load deminishe's, your tail out come right back straight, no snap out funny business, just a little whicked fun.[img]/w3timages/icons/wink.gif[/img]
For what I paid, $395 installed myself, it was well worth the benefits I got.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Old Sep 19, 2003 | 12:43 PM
SoCalTed's Avatar
I've noticed most sites say their bars are for the coupe....can they be installed on the Sedan without issue?
Old Sep 19, 2003 | 01:38 PM
BlueMalibu's Avatar
The benefit depends.
A stiffer bar will make the car more stable at higher speeds. At lower cornering speeds a stiff bar will still be stable but may reduce corning speeds because it will not allow the weight transfer that a softer bar would.
In general, the higher the speed of your cornering the stiffer the bar you want. That is why trick race cars have adjustable bars so they can be changed track to track or even corner to corner.
Also, adjustable bars can allow you to tune your car in regards to understeer and oversteer. A stiffer bar on the front generally INCREASES understeer because it prevents weight transfer to the outside tire. A stiffer bar in the rear INCREASES oversteer for the same reason. Most sway bar kits that aren't adjustable come with stiffer front and rear bars. However the rear bar is biased a little stiffer than the front which dials in a little oversteer - reducing oversteer.
Also, the way the bars are mounted makes a different. Factories generally use rubber bushings for a soft noise free ride. Aftermarket bars usually use polyurethane or direct heim joint connections allowing the bars to react quicker and more predictably - but ride quality suffers somewhat.
IMO, adjustables are the best by far. Then you can tune them to your style/roads - but you have to be carefull - long story. A non adjustable set can cause your car to be slower in certain conditions - like low speed autocross.
Old Sep 19, 2003 | 05:34 PM
StudlyMobile's Avatar
for the average driver, enjoy the sporty car, will not be racing it nor tearing through town, is it worth changing the sway bar on a 6mtC?
Old Sep 19, 2003 | 07:34 PM
3point5SE_Auto's Avatar
once you get the mod fever, yes it will be but you can't get the mod fever until you add and intake and an exhaust and HEAR what this car is capable of.
Better Life thru Chemistry
Old Sep 20, 2003 | 01:43 AM
deadmanincbh's Avatar
What is the advantages of a tower bar?
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
