03 Sedan Manual Shift
Old Jun 12, 2006 | 01:36 PM
mza4's Avatar
When I shift from D to Manual mode the tranny automatically jumps shifts to 4rth gear regardless of my speed. I recently had an 04.5 loaner and it would shift into the correct gear. It appears than in manual mode the car shift up and down through the gears up to the selected gear. So if I have it in 3rd, it goes back abd fourth between 2nd and 3rd, but never any higher.
Anyone aware of any transmission changes from 03.5 to 04.5? I like being able to shift the gears myself when it is in manual mode.
Old Jun 12, 2006 | 01:50 PM
tkman00's Avatar
03s default to 4th gear when dropped into manumatic mode.
Old Jun 12, 2006 | 02:12 PM
AlcatrazT2's Avatar
I have an 06 and it does the same.
Old Jun 12, 2006 | 02:14 PM
Cobra-2-G's Avatar
Just kick the transmission to let it know that you mean business. That may help.
Old Jun 12, 2006 | 02:35 PM
EZZ's Avatar
EZZ
Search is your friend
If you are too lazy, here is the breakdown: 03-04 on sedan = top gear selector, 04.5 to current on sedan = manumatic, all coupes = manumatic.
Old Jun 12, 2006 | 02:37 PM
mza4's Avatar
Could it be that the sport package sedans have a different tranny?
Old Jun 12, 2006 | 02:38 PM
mza4's Avatar
ok Thanks EZZ
Old Jun 12, 2006 | 09:53 PM
sliderg35's Avatar
I have the sports package (03.5) - it always goes to 4th on switch to manumatic.
Old Jun 13, 2006 | 12:50 AM
Fassster10's Avatar
question guys when you are downshifting are you suppose to break or just downshift w/o breaking? has anybody noticed better mpg with manumatic mode...it might be just me but i got better mileage with manumatic!!!
Old Jun 13, 2006 | 01:32 AM
mackinnr's Avatar
same here with 06 sports package
Old Jun 13, 2006 | 11:31 AM
sliderg35's Avatar
You don't need to break. The trans will not shift if your RPM is too high. I always use manual mode so I don't know what my mileage would be like in auto.
Old Jun 13, 2006 | 12:41 PM
Jeff92se's Avatar
Red Card Crew
Try it while at a stoplight
Old Jun 13, 2006 | 12:47 PM
mackinnr's Avatar
it will go to 1st if I am at a stop, do the model year < 05 go to 4th no matter what, even at a dead stop?
Old Jun 16, 2006 | 05:12 PM
mza4's Avatar
Anyone know if this can be changed. Anyone succesfully modify their sedan tranny to operate like the coupe tranny. The manual shift on the sedan is horrible, its shifting is unperdictable. Anyone know if it simply a programming change or is it a different tranny altogether.
Old Jun 16, 2006 | 06:30 PM
jameyb's Avatar
I have an '05 and mine does not always default to 4th. It will go immediately into 2nd or 3rd if appropriate (I usually still have to downshift 1 gear but that's just because I drive like a bat out of hell). It will not, however, immediately go into fifth, it always goes to 4th if I am traveling at a high speed (i.e. 60 to 80 mph) even if the car was in 5th while driving in automatic mode.
tiguy99
Mar 1, 2016 11:42 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
derres
Aug 28, 2015 03:27 PM
NemesisGee
Aug 11, 2015 07:10 PM
nervseele
Jul 17, 2015 11:21 PM
