oem coupe wheels/tires on sedans?
Jun 23, 2006 | 02:24 PM
hey ya'll i finally got a set of some sweeet coupe wheels/tires in mint condition thanks to javier (JC-RH) for hooking me up! anyway the ride is perfect maybe a little noiser but everything else is fine. i was noticing that the coupe rear tires seem to be a little taller (chunkier) than the fronts. my car is lowered 1.3front/0.7rear and it does not rub at all but i havnt had people in the back yet. i believe the stock tire sizes are 245/40/19 is there any other tire that is a bit more "lower profile" so that there would be more clearance for rears?? i think this would help out a bit?
Reply 0
Jun 23, 2006 | 02:58 PM
I put the 225/45/18's all around on mine since I have the eibach 1" lowering springs since whenever I had another person in the car I had scraping - as someone said here make the mods fit the car, not the car fix the mods - i decided against rolling the fenders. I would cehck out the miata tire calc and see what profile will give u the least amt of rubbing / speedo error.
Reply 0
