Staggered Tires on sedan
Old Jul 11, 2006 | 05:42 PM
Oxymark's Avatar
Will putting staggered tires (225 front, 245 rear) on an 06 6MT sedan (stock 235/45/18) cause a problem with the VDC?
Marko:
Old Jul 11, 2006 | 07:30 PM
Chico's Avatar
No it will not. It's been done 1,000,000,000+ times...or there abouts.
Old Jul 11, 2006 | 07:52 PM
Klubbheads's Avatar
vdc it self is a problem. so changing the tires IS not going to make a difference.
Old Jul 12, 2006 | 04:11 AM
ttrank's Avatar
Grocery getter
Nope.
I have had 245's front and 275's rear with no problems.
Old Jul 12, 2006 | 06:12 AM
G35Frank's Avatar
255 fronts 285 rears...not a problem here
Old Jul 12, 2006 | 05:51 PM
LuXXXz's Avatar
im not positive but i think he's talking about the stock non staggered rims, he wants to put staggered tires
Old Jul 12, 2006 | 06:24 PM
gfolo19's Avatar
yeah i have the same question if i put a (225,235)/40/19 on my front 8.5" width tire, and 245/40/19 on the front will it 1) fit? 2) **** up the VDC?
Old Jul 13, 2006 | 01:18 PM
jimmyc13's Avatar
You still haven't resolved what you're gonna go with?
You know that 245/40/19's fit on all fours...We PM'd each other a while ago & I see that you've made some posts on some other threads....so why would you ask if 225's and 235's fit on the front? Then ask if 245/40/19 fits on the front?
If you have a RWD sedan, the VDC is fine....staggered and non-staggered setups are fine & you'll have no issues.
Old Jul 13, 2006 | 01:28 PM
johnadlertech's Avatar
On the stock 05-06 18" sedan sport rims has anyone had any problems with clearance using 245/45/18's all the way around? It looks like wider tires will hit the lip in the wheel wheels. I know that the 245 are barely rated for 7.5" rims but as we know their is a poor selection of 235 and why would I want to go smaller with 225.
Old Jul 13, 2006 | 02:47 PM
Chico's Avatar
245/45/18 all around will not be a problem. Far from it!
Old Jul 13, 2006 | 03:17 PM
vodkarocket's Avatar
Modded Member
Chico, what size tires do you think I can put on my OEM 17x7's? I'm thinking 235/50/17 would be the max, but they don't offer that size for the tires I want: http://www.edgeracing.com/tire/1534/
They have them in 245/45/17- is that too low of a sidewall/too wide of a tire for the 17x7's?
Old Jul 13, 2006 | 03:56 PM
Jeff92se's Avatar
Red Card Crew
You need to read the specs on each tire to see their rim width recommendations. Seems okay to me
http://www.falkentire.com/rt615_sizes.html
AZENIS RT-615 200-A-A
Load / Item # Meas. Approved OD Section RPM Tread Tread Weight Max PSI Max Reinforced
Size Speed Rim Rims Width Width Depth (lbs) (Cold) Load
195/60R14 86H 2835-2440 6.0 5.5 - 7.0 23.2 7.9 900 6.6 8/32 18.7 51 1,168
205/50R15 89W 2835-2540 6.5 5.5 - 7.5 23.2 8.2 895 7.6 8/32 20.8 50 1,279 Reinforced
225/50R16 92W 2835-2642 7.0 6.0 - 8.0 24.8 9.0 881 8.2 8/32 25.2 51 1,389
215/45R16 86W 2835-2641 7.5 7.0 - 8.0 23.6 8.4 768 8.0 8/32 21.7 51 1,168
205/40R16 83W 2835-2640 7.5 7.0 - 8.0 22.5 8.5 911 7.2 8/32 18.2 50 1,074 Reinforced
215/45R17 87W 2835-2748 7.0 7.0 - 8.0 24.7 8.3 871 8.0 8/32 23.1 51 1,201
225/45R17 94W 2835-2742 7.5 7.0 - 8.5 25.0 8.9 822 8.3 8/32 25.3 50 1,477 Reinforced
245/45R17 99W 2835-2743 8.0 7.5 - 9.0 25.6 9.6 806 9.1 8/32 28.7 50 1,709 Reinforced 205/40R17 84W 2835-2740 7.5 7.0 - 8.0 23.4 8.5 875 7.2 8/32 19.4 50 1,102 Reinforced
215/40R17 87W 2835-2741 7.5 7.0 - 8.5 23.9 8.7 861 7.4 8/32 21.2 50 1,202 Reinforced
235/40R17 90W 2835-2747 8.5 8.0 - 9.5 24.4 9.6 836 8.7 8/32 24.3 51 1,323
255/40R17 94W 2835-2744 9.0 8.5 - 10.0 25.0 10.3 825 9.4 8/32 27.5 51 1,477
275/40R17 98W 2835-2745 9.5 9.0 - 11.0 25.6 10.8 806 10.0 8/32 28.8 51 1,653
225/45R18 91W 2835-2841 7.5 7.0 - 8.5 25.9 8.9 794 8.3 8/32 26.1 51 1,356
255/45R18 99W 2835-2849 7.0 7.0 - 8.0 27.0 8.3 840 8.0 8/32 30.4 51 1,201
225/40R18 92W 2835-2840 8.0 7.5 - 9.0 25.1 9.3 818 8.3 8/32 24.5 50 1,389 Reinforced
235/40R18 95W 2835-2842 8.5 8.0 - 9.5 25.5 9.6 806 8.7 8/32 25.5 50 1,521 Reinforced
245/40R18 97W 2835-2843 8.5 8.0 - 9.5 25.6 9.8 803 9.1 8/32 28.4 50 1,609 Reinforced
255/40R18 95W 2835-2844 9.0 8.5 - 10.0 25.9 10.3 794 9.4 8/32 27.8 51 1,521
295/40R18 103W 2835-2850 10.5 10.0 - 11.5 27.2 11.9 763 10.9 8/32 34.0 51 1,929
265/35R18 93W 2835-2847 9.5 9.0 - 10.5 25.4 10.7 852 10.0 8/32 28.7 50 1,609 Reinforced
275/35R18 95W 2835-2845 9.5 9.0 - 11.0 25.6 10.8 803 10.0 8/32 28.6 51 1,521
315/30R18 98W 2835-2848 11.0 10.5 - 11.5 25.6 12.4 813 11.7 8/32 32.3 51 1,653
Old Jul 13, 2006 | 04:30 PM
Chico's Avatar
Well, the OEM tires are 215/55/17. So you can go up two sizes in WITDH without any problems. So you can do 225/55/17 or the 235/50/17 which is a better fit (closest to OEM). Toyo T1R is your best bet 235/50ZR17 96Y PRODUCT CODE 546510
Old Jul 13, 2006 | 04:51 PM
Modded Member
I need something stickier. I'm looking for dedicated autox tires, so the T1R's won't do (those are going on my other wheels though).
Old Jul 13, 2006 | 04:56 PM
IQ9's Avatar
IQ9
There are some folks on here running 245/45/17 on the stock 17x7 with no issues. I run them but on a 17x8 inch rim. I have had no issues with this size and there are many choices although some seem to be going away. Edgeracing has there MUSH sale going currently and it woyld be a perfect time to get your tires. I just bought some ST-115s to replace the Toyos...$85 is too cheap to pass up.
