Need help from Sedan Owners with Vortech SC
Old Aug 2, 2006 | 11:18 PM
StarChamp's Avatar
In my efforts to find out if the Vortech SC for 05 350Zs and G35s (Part #'s 4NZ218-060SQ and -068SQ) will fit on the sedans, I got this reply:
Vortech has not verified fitment in the 05+ sedan models. However in previous sedan models the mechanical fan caused clearance issues with the supercharger kit. Also, in past sedan models, the intercooler tubing needed to be modified in order to fit properly. Vortech cannot guarantee that computer programming is compatible with sedan models, so a custom computer tune may also be needed.
Can you Sedan owners running the Vortech verify/quantify these fitment issues? Will the electric fans in the 05 alleviate the clearance problem, or just make it not fit someplace else? How extensively did you have to modify the precooler tubing? ECU probs? Thanks for whatever assistance you can provide.
I'm really starting to regret holding out for those extra 28 horses....
Old Aug 3, 2006 | 08:29 PM
transportchef's Avatar
Try the forced induction section or same section in my350z.com.
Old Aug 3, 2006 | 10:38 PM
ttrank's Avatar
Grocery getter
I think there was one sedan with the vortech but I doubt he was an 05+.
You don't have mechanical fans that was 03 only (I believe).
As for the tubing most shops should be able to make minor mods if needed.
Same goes for the ECU because the SS box they use should work fine but they can make sure when they tune it.
Old Aug 3, 2006 | 11:05 PM
Xman's Avatar
I have an '04 sedan with electric fans. Bring it to a shop fitment shouldn't be a problem.
+1 on checking FI section on my 350z.com
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
Phenomenon9
Aug 9, 2015 01:34 AM
Srinidhi
Aug 7, 2015 03:38 PM
