Can anyone let me know which wire off the CPU is the TPS & rpm signal?
or post a pic of the wire harness. i currently have the TPS wire tapped in at the throttle body.i would rather tap into the CPU for the signal. i was told to tap into yellow red wire (PIN 50) , but there are 2 red and yellow. 1 thicker gauge then the other.
.. and which wire for RPM from CPU i was told 62? but what color is that wire?
thanx
thanx
