NE1 consider cutting their huge under body spash sheild?
Old Aug 29, 2006 | 06:35 PM
Jeff92se's Avatar
Red Card Crew
So you don't have to remove the entire thing to do oil changes? Last time I only unscrewed 1/2 of them and bent it down but it was awkard getting the drain pan up to catch the oil draining from the filter. Not sure how this would work because if you cut one side, the other won't be supported. Maybe cut and insert a sheet that spans both sides. So the side you take off has extra material that you slide under the other piece that has the screws.
engine
___~___
ground
Or has anyone just cut a larger hole so the filter can be accessed w/o removing the shield?
Old Aug 29, 2006 | 07:32 PM
ttrank's Avatar
Grocery getter
I use a cordless drill with a skew driver and 10mm bit to take the cover off. It only takes a minute.
Old Aug 29, 2006 | 07:33 PM
Jeff92se's Avatar
Red Card Crew
Yes I do this too but it's still a pain.
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
