Turn Signal Bulb - What Size?
Old Jan 18, 2003 | 01:39 AM
adrenalinepump's Avatar
After 13,500 miles in 5 months my left turnsignal has finally decided to die on me :-( ... What size bulb do I need to get and how do I access the headlight housing, through the wheel-well?
Thanks!
Frank
http://www.adrenalinepump.com
Old Jan 18, 2003 | 10:57 AM
Merlin's Avatar
Staff ALUMNI
Re: Turn Signal Bulb - What Size?
There is a small recess that a screw driver pushes on a tab to unclip, the assembly then pops out. Don't have to remove the wheel etc.
Sorry, don't have the specs on the bulb handy.
Merlin.
Old Jan 18, 2003 | 01:21 PM
Gordgee's Avatar
Administrator
If you go back to the dealer, the bulb should still be under warranty. Unless you really want to take things apart.
Old Sep 13, 2012 | 09:07 PM
DVG's Avatar
DVG
It is a 7440
Old Sep 13, 2012 | 09:47 PM
05_SkylineSedan's Avatar
20 Year Member
Dealer / warranty is probably the best advice.
Depending on the year of your car (?) if you're asking about the main blinker / parking lamp which is part of the headlamp housing then that one (for 05/06) is a dual filament 21/5w. And yes, I believe access is via the wheel well.
If you're talking about the "side marker" then what Merlin said above, easy access.
Old Sep 13, 2012 | 09:50 PM
DVG's Avatar
DVG
^Something tells me this is not for an 05/06
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
