'06 350Z Springs & Shocks fit on '06 G35 Sedan
Old Sep 16, 2006 | 02:48 PM
jameyb's Avatar
I put the coupe springs on the rear so it would sit a bit higher than with the z springs. If you look at the measurements in the post you can see exactly how much. I did not like the way the car looked lower in the rear with z springs. The easy fix was to install coupe springs and now it sits perfect in my opinion.
Others like it with z springs all around. It just depends on what you like. As far as I know, all z springs are the same height. I am pretty sure I would have wanted to change the rear springs even if I had used 06 z springs.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
LoSt180
Jul 15, 2015 08:31 AM
