Trunk Release Problem
I have an 03 sedan with the "doggy latch" trunk. I am having a problem with the release switch not opening the trunk, the key fob works but when i press the release switch on the trunk nothing happens. I've check the switch in the glove box and nothing, but i've noticed that the key fob release works both in the on and off position. Anyone experience this problem before? Any help would be appreciated.
Perhaps the switch? Is there anyway to test this? Is there another way of opening the trunk besides the key fob and the release on the trunk?
Yea i was going to mention the Switch in the glove box.. But idk what to tell you.. I had the same prob then i learned about the switch .. Did you Flip the switch to the on Postion While the car is runing? idk.. GL tho
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
