Another Wheel Question (uh oh!)
Old Sep 21, 2006 | 08:05 PM
Neal376's Avatar
Originally Posted by ttrank
I thought the camber kits just pulled the bottom the wheel in to fix the camber. I don' think that will help the rubbing.
its adjustable to both ends, I can adjust it to a negative position as well
Old Sep 21, 2006 | 08:08 PM
ttrank's Avatar
Grocery getter
But how does it adjust it? I thought it just moved the bottom of the wheel. The top would stay in about the same place.
I guess if you had way more negative camber the wheel might tuck a little more.
Old Sep 21, 2006 | 08:14 PM
Neal376's Avatar
wait, so your telling me I have to run 275/30's (rubberbands?)
Old Sep 21, 2006 | 08:15 PM
Neal376's Avatar
it should work
Old Sep 21, 2006 | 10:14 PM
tkman00's Avatar
you want to drive from maine to ny w/ negative camber?
Old Sep 21, 2006 | 10:52 PM
Neal376's Avatar
yea, check out those Nitto Neogens. Apparentely they are built with a harder compound on the inner rubber to fight the effects of neg camber
Old Sep 22, 2006 | 12:55 AM
kenasaki's Avatar
question
hey dont mean to thread jack.
but will 19x9.5 and 19x10.5 with an offset of +25 all around fit on the sedan? and i'm also going to drop it later too.
im about to get the Junction Produce's Scara wheels.
thanks
Old Sep 22, 2006 | 01:01 AM
Chico's Avatar
thanks
no they won't. Those offsets are for coupes and 350Z.
Old Sep 22, 2006 | 01:08 AM
kenasaki's Avatar
damn...so do you know what will? is there a size and offset chart for sedans that someone can link me to?
Old Sep 22, 2006 | 01:10 AM
Chico's Avatar
look at my earlier post. The answer is in there.
Old Sep 22, 2006 | 01:31 AM
kenasaki's Avatar
so for the rear...is it better to get 19x9.5 with a +40 or +45 offset? bc i want to go staggered wheels as well. but what will the slight camber do to the tires? and if i ever hit a bump or something, will the rims get damaged by the fenders?
thanks, i really want those Scaras. has there ever been anyone with those rims on a sedan?
Old Sep 22, 2006 | 01:49 AM
ttrank's Avatar
Grocery getter
I can tell you that I have 20x8.5F +40 and 20x10R +43. I had to roll my rear fenders to fit the 10's with 275/30's.
Old Sep 22, 2006 | 09:16 AM
tkman00's Avatar
ditto - i posted a link on the first page of this thread
Old Sep 22, 2006 | 03:06 PM
seddon's Avatar
Neal not to go off the subject but I think with the AWD fuse pulled I also loose my VDC am I wrong or do you have the same problem.
Old Sep 22, 2006 | 03:08 PM
  #30
Neal376's Avatar
my vdc works fine with AWD off. VDC is another fuse all together - in that fuse box next to the battery
