tire pressure sensor
Old Oct 18, 2006 | 12:36 AM
kenasaki's Avatar
well all, this morning, i started up my car and a warning indicator came on. I was dazed and suprised that it turned out to be the tire pressure was low. i went to the gas station pumped it to 50psi and was on my way with the warning indicator gone.
well, i'm getting 19 inch tires now, so will the tire pressure sensor still work? and will it still give me an indicator warning in the dash? or will it just do nothing?
thanks everyone.
Old Oct 18, 2006 | 01:10 AM
ttrank's Avatar
Grocery getter
You will need to have your sensors put in the new wheels. They activate the warning light when your tires have 28lbs or less in them.
Old Oct 18, 2006 | 02:04 AM
digital1986's Avatar
damn............50 psi . . .
Old Oct 18, 2006 | 02:43 AM
fulanoderock's Avatar
word, that was what i was thinkin. i have 35 psi in mine.
Old Oct 18, 2006 | 04:02 AM
G35_RJ's Avatar
UHH 50PSI? ...aren't you worried about your tire blowing up when it heats up?
Old Oct 18, 2006 | 08:41 AM
AgentAero04's Avatar
50 PSI !!! You sure its a G35 and not a Massey Ferguson.
Old Oct 18, 2006 | 09:13 AM
SilverII's Avatar
better not hit any potholes. You might pop that tire
Old Oct 18, 2006 | 09:21 AM
da mayor's Avatar
bring it into the dealer and they can reset the pressure and psi it's set at
Old Oct 18, 2006 | 12:37 PM
ttrank's Avatar
Grocery getter
My 20" tires can hold 50psi. I run them 38-40 most of the time. I tried 35 but they started to wear even faster on the inside.
Old Oct 18, 2006 | 12:49 PM
jimmyc13's Avatar
Damn....50 psi is usually the max...damn that must be a firm ride...kinda risky!
Da mayor - when I had my TPS's put in my Milano's by the dealership, I asked them to reprogram them to increase the min. PSI setting (to like 32 or so) and they said it cannot adjusted? I know you work at a dealership & wasn't sure what you knew that they dont?
Old Oct 18, 2006 | 01:00 PM
kenasaki's Avatar
really?! i didn't know, i just read on the tire, so thats what i went by. i'll deflate it, but it did gimme a somewhat firmer ride. thanks guys
Old Oct 18, 2006 | 01:03 PM
ttrank's Avatar
Grocery getter
Yeah I would stay away from the max. 40psi is a good place for wear and a firm ride.
Old Oct 18, 2006 | 01:08 PM
kenasaki's Avatar
^thanks for answering my next question of how much to put.
Old Oct 18, 2006 | 01:09 PM
ttrank's Avatar
Grocery getter
Actually that depends on the tires. If the max is only 44 then I would run ~37-38. If the max is 50 then I run 40.
Old Oct 18, 2006 | 01:38 PM
Msedanman's Avatar
O.F. Administrator
What's on the sidewall is Maximum safe inflation pressure, not what is recommended for service.
Your sedan should be around 30. I ran mine about 33-35 tops.
You'll need new sensors for the new wheels which will then have to be initialized by the dealer.
C.
