Sedan 6MT - Tire Pressure Monitor System
Old Oct 23, 2006 | 07:39 PM
krishlad81's Avatar
I have a 2006 Sedan 6MT with Premium & Aero package. I have lately noticed that everytime I have my car parked out in the cold - the TPM system warning light comes on. It stays on until I park the car in the garage at night and then stays off.
I have had couple of technician look at it and they said that the tires had proper pressure and that there was no problem - it was probably because the cold air inside the tire is more dense. They recommended using nitrogen.
Has anyone used Nitrogen instead of regular air - noticed any improvements in ride quality or maybe worse?
Thanks,
Kunal
06 Sedan 6MT
Black on Black
Premium & Aero Package
Old Oct 23, 2006 | 08:38 PM
ttrank's Avatar
Grocery getter
There are lots of people who use it. I wonder where I could get some around here?
Old Oct 23, 2006 | 08:51 PM
thorin's Avatar
Dallas is getting some "chilly" weather and last Saturday, my tire inflation lite came on and would not go out, even though the pressure was fine - 13 mile drive. Was still on the next morning; even double checked to be sure there was no sensor in the spare. If it does it again, I will check with the dealer.
Old Oct 24, 2006 | 10:01 AM
350Zed's Avatar
Just pump up your pressures over stock and when the temp dips you'll still be at or over stock pressures.
I used to run 35-36psi on my 350Z and 38-40psi on my Eagle Talon for better handling... you just get a harsher ride and a bit more tire-wear in the centre of the contact-patch.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
joedaddy1
Jul 28, 2015 02:58 PM
multimut
Canada
Jul 26, 2015 08:43 PM
