Door lights - how to swap?
Old Oct 29, 2003 | 03:17 PM
G_Money's Avatar
I want to change the bulbs under the front doors (the ones that shine on the ground when you step out of the car). I can't figure out how to remove the plastic cover though. Has anyone done this? Is there something in the service manual on how to remove the plastic cover?
Old Oct 29, 2003 | 05:03 PM
ncozby's Avatar
Re: Door lights - how to swap?
I replaced mine a few days ago. You can easily access them by removing the door panel. Here's the steps i posted a while back on removing the door panel, it's very easy. I did both lights in 5 minutes.
- Pop off the wood panel trim on the door, assuming you have the wood option, if not it is silver trim on the door. You can pop it off by hand by pulling it gently from the underside, or you can use a small flat-head screwdriver to pry it gently.
2 - Remove the 2 screws in the door handle hidden behind the wood panel you just removed.
3 - Remove the small 'square' near the door handle with a flat-head screwdriver, and remove the screw now exposed that was hidden behind the square.
4 - Pop off the door panel on the front bottom edges gently. Then lift the entire door panel off as one piece, and gently rest it on the door frame or let it hang. It will not come completely off without unhooknig some wiring harnesses, but we dont need it all the way off for what we are doing anyway.
Once you get the door panel off, just pop the bulb out of the housing at the bottom in put yuor new bulb in, put the door panel back in place, all done. [img]/w3timages/icons/smile.gif[/img]
<font color=blue>2003 G35 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon w/Silverstar Fogs
35% Tint All Around - Clear Corners
MB Quart / Eclipse Stereo System
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Oct 29, 2003 | 05:54 PM
wickedel's Avatar
Great post! What color lights did you put? part # ? and where you bought them? Thanks.
Old Oct 29, 2003 | 08:23 PM
ncozby's Avatar
Here's the bulbs I used. They match my PIAA Extreme White interior lights exactly.
http://store.yahoo.com/racinglab/rayr1platwhi.html
mike730
Jan 12, 2018 04:25 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
joedaddy1
Jul 28, 2015 02:58 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
