removing door panel
Old Oct 25, 2006 | 01:46 AM
chinaman_87's Avatar
removing door panel
i haven't seen this discussed here just wondering whats the easiest way to take the door panel off? thanks
Old Oct 25, 2006 | 02:14 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Take off the aluminum trim. There's a little slot on the bottom to stick a flathead screw driver in and just pop it out. There's two 10mm bolts in there, remove them. Then inside the shroud for the handle there's a square that pops out with a flat head. Remove the 10mm bolt that is now exposed. Then on the outer edges of the door panel, pull it away and the clips will pop out. Once you have all of them out, lift the door panel up off the window. Viola, your done.
-GP-
Old Oct 25, 2006 | 02:42 AM
thanks for the quick reply
Old Oct 25, 2006 | 06:51 AM
35bills's Avatar
Is this the same procedure for the rear doors aswell?
Old Nov 2, 2006 | 11:54 AM
Mike_Deezy's Avatar
Is this the same for a coupe? Do you mean the aluminum trim that's on the door handle?
Old Nov 2, 2006 | 11:56 AM
Yes this is the same procedure for the coupes and sedans. It is very straight forward, just dont yank it too hard when you're tryin to pull the panel away from the door. The aluminum door trim is what you have to remove to reveal the 2 10mm bolts sunken into the handle.
-GP-
Danielek
May 1, 2022 01:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
