View Poll Results: Does your suspension squeak/creak ever?
I have a compression rod problem - stock suspension
60.11%
I have a compression rod problem - modified suspension
14.61%
I do not have a compression rod problem - stock suspension
15.17%
I do not have a compression rod problem - modified suspension
10.11%
Voters: 178. You may not vote on this poll
G35 Compression Rod Problems
Old Nov 17, 2006 | 08:59 PM
absolutg's Avatar
workin...
keep it coming guys with the votes, if we can get 40-50 ppl calling within a short time span that could help us significantly
Old Nov 21, 2006 | 12:02 PM
absolutg's Avatar
workin...
bump
Old Nov 21, 2006 | 04:41 PM
SixFive's Avatar
Connecting and Compression rods are not the same are they?
Old Nov 21, 2006 | 04:55 PM
dklau33's Avatar
the connecting rods as stated in lexusk8's post are the same thing as the rear sway bar end links. not the same as the front compression rods.
Old Nov 25, 2006 | 10:20 PM
lexusk8's Avatar
Today I got my car back from the dealer and had the compression rods from the front replaced under warranty. Here's the receipt:
Customer states there is a squeaking when going over bumps. Found compression rods bearings have excessive play. Replaced compression rods.
COMPRESSION ROD, FRO-54469-AC70F $173.15
BOLT-STOPPER, 40038-AL510 $6.79
ROD COMPL-COMPRESSIO, 54468-AC70F $173.15
BTW, the '05 G35 loaner I was lent for a couple days does have that similar squeaking noise in the front when going over speed bumps. I'm sure this issue is more obvious on the loaner vehicles since they are typically driven hard.
Old Nov 26, 2006 | 12:32 AM
cloud's Avatar
which dealer did you go to? happens on my coupe for some reason
Old Nov 26, 2006 | 12:42 AM
AgentAero04's Avatar
Originally Posted by G35_4_Me
Mine's an '04 X with about 35K miles on her. I had the issue fixed once back in May (don't remember the mileage) and it started creaking again last month. I plan on bringing it back in for service some time soon. I hope they don't give me the run around.
Back in May, the tech told me that they can fix it but that it's going to keep coming back. I'm worried about having to fix this issue after my warranty runs out. Infiniti has to resolve this problem.
Its really an issue with the type of rubber bushings they use on the compression rods,not the compression rods themselves.And it well keep coming back until Infiniti looks for another material or supplier for bushings,they can grease them all they want.Infiniti should step up to the plate and have a recall on this part.
Old Nov 26, 2006 | 04:38 PM
lexusk8's Avatar
Orlando Infiniti. They've been very good to me for service work and quality of customer service (better than the experience with my previous Lexus).
Old Jan 24, 2007 | 08:02 PM
jondimellow's Avatar
bump
Old Jan 24, 2007 | 08:38 PM
Floyds_racing's Avatar
well I have a 03.5 about to roll 50k with tein flex suspension and its starting to creek and it drives me crazy? I was thinking it was the suspension and it needing to be rebuilt!! how long should it last and if it is compression rod how much to replace!
Old Feb 16, 2007 | 01:53 PM
c35's Avatar
c35
$780 for compression rods??
My dealer quoted me $780 for compression rods last night (installed, of course... so kind) for my wife's 2003 G35 with 87K miles. Yikes!
Any aftermarket recommendations??
Old Feb 21, 2007 | 07:11 PM
absolutg's Avatar
workin...
damn that's crazy expensive. i got mine serviced under warranty a few weeks ago. i hope infiniti comes up with an appropriate solution soon. btw, you don't need to actually replace the rods, just the bushings that the rods use. that should save you a lot of $
Old Feb 21, 2007 | 09:08 PM
Noremac's Avatar
Originally Posted by absolutg
... you don't need to actually replace the rods, just the bushings that the rods use.
That's technically correct, but the question is whether the bushing parts are available separately from Infiniti or other supplier. I don't believe they are available from Infiniti that way. Anyone know?
Old Feb 21, 2007 | 10:53 PM
Chrlesmd's Avatar
How does this affect the performance or handling of the car if you don't get them replaced? Is it dangerous?
Old Feb 22, 2007 | 11:37 AM
  #30
Noremac's Avatar
My understanding is the the problem is strictly noise, and there are not any mechnical or structural issues.
