Show Me Your Blacked out Sedan Headlights
Old Nov 21, 2006 | 12:34 PM
G35Dreamz's Avatar
Originally Posted by ttrank
Just DIY. It's not hard, just takes time. If you can come up with a couple days to spend on it you will be good to go.
I have done a DIY before but the outcome wasn't good. I think it had to do with the shape of the low beam area. I think with the G it will be easier. I will do it eventually, i have all the parts from my previous work.
Old Nov 21, 2006 | 01:02 PM
ttrank's Avatar
Grocery getter
That's better.
Old Nov 21, 2006 | 02:38 PM
350.GT's Avatar
ttrank Ive done the project before with my 01 tl but after baking it the outer lens were messed up? and im to lazy to wet sand it and buffing it out. how did you do yours.
Old Nov 21, 2006 | 02:45 PM
rijen1013's Avatar
black headlights
here you go
Old Nov 21, 2006 | 03:02 PM
ttrank's Avatar
Grocery getter
What temp did you bake them at and for how long? I have had mine in the oven three different times and don't have any problems with them.
Old Nov 21, 2006 | 03:33 PM
350.GT's Avatar
I set mine at 250dg. and lefted them in for 2min then took them out and start pullin and stuck in back in. took me 3 trys. for each one. but the outer lens gets all flakey.
Thanks for the info.
-Loc
Old Nov 21, 2006 | 03:36 PM
350.GT's Avatar
rijen,
yours look hella clean..... why does your hi's look yellow?
Old Nov 21, 2006 | 03:44 PM
G35Lin's Avatar
Multi-Spoked Mod
Hey,
TSX modified BIXENON for the top. used E46 shrouds with custom LEDS.
M45s on the bottom.
15watt LED turn signal with a projector lense for the signal.
PIAA 6600K bulbs for all four.
Ed Lin
Old Nov 21, 2006 | 04:00 PM
g35sedan5at's Avatar
^^^ wow me likey just from the description, mind posting some pics
Old Nov 21, 2006 | 04:15 PM
ttrank's Avatar
Grocery getter
Originally Posted by G35Lin
Hey,
M45s on the bottom.
Ed Lin
TSX is not a bi-xenon; it's a low beam only. Did Larry somehow make them a hi/lo?
Is the bottom M45 projector and shroud?
Old Nov 21, 2006 | 04:16 PM
ttrank's Avatar
Grocery getter
His pics are up higher in this thread.
Old Nov 21, 2006 | 04:42 PM
G35Lin's Avatar
Multi-Spoked Mod
ttrank. well, MINE is NOW! :P bixenon...TSX projectors it is
Ed Lin
Old Nov 21, 2006 | 05:18 PM
BuckeyeG's Avatar
Ive got Bats 3/10 overlays on mine.
Attached Thumbnails Show Me Your Blacked out Sedan Headlights-dsc00163-medium-.jpg
Old Nov 21, 2006 | 05:25 PM
ttrank's Avatar
Grocery getter
Ed Lin
That's awesome. So the upper projector is Lo/Hi and the lower projector is just the fog? More like the 06' coupe lights.
Old Nov 21, 2006 | 05:27 PM
  #30
G35Dreamz's Avatar
Hey,
M45s on the bottom.
Ed Lin
All that must of cost more than 2 grand!!!!
Originally Posted by rijen1013
here you go
Lovin' the blue and gold! Might go with that route but with bronze.
