Calipers
Old Dec 7, 2006 | 01:36 AM
UPandCOMING.G35's Avatar
Question Calipers
Anyone know were i can get my calipers painted in the socal area??
Old Dec 7, 2006 | 01:41 AM
RPL's Avatar
RPL
Why not do it yourself?
Old Dec 7, 2006 | 01:45 AM
Red face
and how abouts would i go on doing it myself?
Old Dec 7, 2006 | 02:33 AM
G35Papa's Avatar
It's easy. I've done it about 3 times myself....Gold, Blue..now gloss black.
Clean, wipe down, mask off, then paint. Drys in like 15 to 20 minutes.
http://www.tirerack.com/brakes/g2/caliper_paint.jsp
Old Dec 7, 2006 | 02:41 AM
skeleton_cru's Avatar
Sedan
If you want them to look really nice get them powdercoated.
Old Dec 7, 2006 | 02:54 AM
G35Papa's Avatar
^I agree...the finish is way better then you will be able to get by doing it yourself.
Old Dec 7, 2006 | 03:17 AM
rijen1013's Avatar
its pretty easy to do it yourself kragen has a kit for about $20 bucks
Old Dec 7, 2006 | 06:37 AM
BuckeyeG's Avatar
I got my paint at autozone for like $8
Old Dec 7, 2006 | 07:29 AM
ma_sha1's Avatar
Caliper
If you like blue, you can buy mine &
sell yours. Save you time & money.
My is painted blue & has infiniti longo on.
$150 for brake rotor, pad, calipers, lines the whole front.
Old Dec 7, 2006 | 08:39 AM
bert039's Avatar
Are you stripping away the old paint before you apply the new paint?
Old Dec 7, 2006 | 01:13 PM
G35Papa's Avatar
When I went from Gold to Blue I did. I didn't when I went from Blue to Black. I just cleaned them up before I went black. The finish on them was already very smooth.
The trick to using those kits is to first put a light coat on, let it dry, then put it on thick. You don't have to worry about smears or brush marks. The paint seems to have alot of alcohol it (or something) and dry's very smooth.
I have extra blue and black if you want it. There is more than enough to do all your calipers.
Let me know
Old Dec 7, 2006 | 02:39 PM
izmir41500's Avatar
G35driver Addict
get the G2 caliper paint. take off your rims. use masking tape and newspaper to mask everything but the caliper. a tip i've heard is to mix 1/4 of the paint at a time so it doesn't dry out on you when you're doing it your first time being extra careful.
Old Dec 7, 2006 | 02:43 PM
ttrank's Avatar
Grocery getter
The paint should be $8-10. I did my oem RB rear kit to mach my front calipers and the red spacer they came with.
I do agree that having them power coated would look a lot better but it's more $ and time.
Old Dec 7, 2006 | 04:57 PM
Question
So paint from kragen or another autoparts store would work fine??
Old Dec 7, 2006 | 05:26 PM
G35Dreamz's Avatar
get hi temp engine paint.
