Camber question
Old Dec 15, 2006 | 03:49 PM
ORANGEBSRT's Avatar
Camber question
With a 1.5 drop in the front on an 06 sedan, is it possible to align close to spec without a camber kit? I'm hearing bad things about the eibach. Some ppl are saying that after they settle, its actually a 1.5 drop and sometimes the back sags. Is this true?
Old Dec 15, 2006 | 05:40 PM
ORANGEBSRT's Avatar
no one has a comment..........c'monnnn
Old Dec 15, 2006 | 11:54 PM
bbug's Avatar
My Eibach kit dropped as advertised. I will need a rear camber kit to control the wear in the rear but the front was ok.
Old Dec 15, 2006 | 11:58 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
the front and rear camber are going to be fairly out of spec, front and rear. Front camber isnt adjustable from the factory on our cars, so it'll be way out either way.
-GP-
Old Dec 16, 2006 | 08:09 AM
ORANGEBSRT's Avatar
so then eibach would be the best way to go to stay at least close to spec?
Also bbug, does your car look lower in the back or is it pretty much level all the around?
Old Dec 16, 2006 | 01:48 PM
bbug's Avatar
Here are the before and after pics. The back is still slightly higher.
Before:
After (sorry about the image size) I reduced it but it's still way too big.
Old Dec 16, 2006 | 02:45 PM
chobble19's Avatar
ive got the h techs with ~1.3 front/0.7 rear drop and both front and rear are slightly out of spec...rear seems a little worse but front gets a little unpredicable at times too...only way to correct this is adjustable camber arms...ive got the rear spc kit going on this week along with the gt specs front tie brace-rear lat bar....the rear tie brace wont be able to fit with the spc!
Old Dec 16, 2006 | 04:26 PM
perry05G35's Avatar
I had the Eibachs on I didn't have any problems with sagging but I did need a camber kit at all 4 corners to get me back into spec. My drop was more than the advertised amount. If you go with any spring including the 350Z/G35 Coupe be sure to monitor your camber and check your tire wear some guys are finding that with the adjustable camber kits you can get your camber in spec but your toe is way off and vice versa. Here are some pixs of the eibachs on I have sense taken them off I am going with 04 G35 coupe springs for 1/2 inch drop all 4 corners.
Old Dec 16, 2006 | 10:04 PM
jimmykce1's Avatar
I installed 350z spring front and coupe springs on the rear. I had to get a front camber kit only to bring the fronts into stock spec's. I installed the SPL front camber kit today. The kit was very nicely made and easy to adjust. I would recommend this camber kit. It cost me 549.00 dollars plus shipping.
Old Dec 17, 2006 | 12:03 AM
+1 for the SPL front camber kit, i would recommend it to anyone. I did an alignment on a coupe with one and they are constructed pretty solid and easy to adjust as well.
-GP-
Old Dec 17, 2006 | 01:18 AM
ttrank's Avatar
Grocery getter
I would look into an SPC camber kit. They have been around for a long time and I have had their kits on a few cars with great results.
You will not be in spec with a 1.5' drop. I am just out of spec with a 1.3/1.2 H&R drop right now.
Old Dec 17, 2006 | 08:40 AM
jimmykce1's Avatar
The SPC front camber kits are having some problems with them and preformance shops cannot get the front SPC camber kits. If I had to get rear camber/toe, than I will get SPC.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
