upgrading d2s bulbs
Old Dec 26, 2006 | 10:23 PM
paul721's Avatar
upgrading d2s bulbs
did the search and couldnt find anything.....i will be upgrading the stock hid d2s bulbs and would like to know what is the easiest way to do this and what proceedure to follow...do i need to disconnect the battery or do anything special before removing the bulbs ? thanks
Old Dec 26, 2006 | 10:26 PM
Garyv01's Avatar
do u have projectors?...if not ure gonna need d2r bulbs
Old Dec 27, 2006 | 12:45 PM
paul721's Avatar
i have a 2006 sedan so i know that my car uses d2s...i was just wondering if there is anything i need to do other than just pulling out the bulbs like i would on any of my cars
Old Dec 27, 2006 | 12:52 PM
patman530's Avatar
If you have a 2006 sedan, you should be using D2R, as you have the reflectors and not projectors.
And no need to disconnect the battery, just undo the latch, twist, take the old bulb out, and put the new one in.
Old Dec 27, 2006 | 01:08 PM
G SEDAN's Avatar
^^^ +100 on the D2R
Old Dec 27, 2006 | 01:22 PM
(>")> G35's Avatar
Stock bulbs are D2R! You can use D2S bulbs if you want, but it'll just throw more glare at drivers coming at you.
Old Dec 27, 2006 | 01:24 PM
az1anbeethoven's Avatar
yes...listen to the advice on the forum...its d2r!
Old Dec 27, 2006 | 01:38 PM
ttrank's Avatar
Grocery getter
All non-projector G's use D2R. I had to change to D2S with my projector mods.
Old Dec 27, 2006 | 02:01 PM
paul721's Avatar
d2r...got it...thanks guys...i was confused....im also going to upgrade the h-1 to match ....should look sweet....
Old Dec 27, 2006 | 02:07 PM
ttrank's Avatar
Grocery getter
You mean H4. The projector headlight on the coupe uses an H1.
Old Dec 27, 2006 | 02:09 PM
excluesiveonez's Avatar
some one is feeding him some pretty shotty info
Old Dec 27, 2006 | 02:14 PM
Nickk6's Avatar
Lol, this is why the forums are good. He would have had 4 useless bulbs if no one told him otherwise
Old Dec 27, 2006 | 02:15 PM
ttrank's Avatar
Grocery getter
I think he just found a list for an 06G coupe thinking they were the same but the coupe and sedan are not.
Old Dec 27, 2006 | 02:18 PM
for real
Old Dec 27, 2006 | 02:45 PM
paul721's Avatar
so just to clarify, what bulbs does my car use ?
2006 g35 sedan ....im so confused and im about to order the bulbs today
