Heated Seats LED bulb
Old Jan 5, 2007 | 10:08 PM
BigSash's Avatar
Originally Posted by Mmagic76
UPDATE: I've successfully located a place that carried the AMBER 3mm LED bulbs as well as the 1/8 watt resistor. Factory resistor was 1300ohms but I opted for a 360ohm resistor (from my LED bulb specs). After sodering the resistor and wire on, I tested it out and it pretty much matches the OEM colour and brightness.
Get this: when they replace your whole switch OEM it doesn't match either. The bulbs always look different new. If you solder the same bulb and res onto the other switch replacing the old bulb that's on there now you will have two matching
Old Jan 5, 2007 | 10:14 PM
Mmagic76's Avatar
I'm just happy that I saved myself $80 on buying a new switch just for the LED bulb!.
nissandrifter32
Dec 22, 2015 04:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
invincible514
Sep 21, 2015 07:05 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
