Dyno G35x with AWD fuse pulled
Old Jan 29, 2007 | 03:51 PM
ma_sha1's Avatar
There is only one AWD dyno around here that's out of business.
I also heard AWD dyno is not accurate.
Can I dyno the G35x on 2wd dyno with the AWD fuse pulled?
Has anyone tried it?
Old Jan 29, 2007 | 04:02 PM
Graphite05G's Avatar
The RV Specialist
I dont think that just pulling the fuse will make it RWD. I think that the best bet would be to drop the front drive line.
Old Jan 29, 2007 | 04:39 PM
KrazyEd's Avatar
I am pretty sure that when you pull the AWD fuse it is 100% RWD. I think that you should be fine but dont take my word for it. I plan on removing the fuse for spring/summer so I can run staggared.
I know that there are a few X owners running without it. Hopefullly, they will give their 2 cents.
Old Jan 29, 2007 | 06:16 PM
psedog's Avatar
Back in SD**
In my old GTR (R32), it had two different fuses, one made it full time rear wheel tire the other made it full time 4 wheel drive. Not sure if the X's are the same way or not, plus I only tested the one that made it rear wheel drive.
Pull the fuse and do a short burnout, you'll know for sure that way.
Old Jan 29, 2007 | 06:21 PM
psedog's Avatar
Back in SD**
I believe the one to make it rwd was under the hood (bonnet) and it was called a heater of some sort. It's been a few years so I forgot what it was called.
Just checked the manual, it was a 30A fusible link called "PTC Heater 4WD"
Old Jan 29, 2007 | 07:02 PM
ttrank's Avatar
Grocery getter
I'm not sure if any dyno shops will even do that. Maybe if you sign something in case it is damaged.
Old Jan 29, 2007 | 07:59 PM
Xman's Avatar
Neal, any comments? I'm not going to be the guinea pig on this one. Lol!
Old Jan 29, 2007 | 08:02 PM
ma_sha1's Avatar
The g35x AWD Fuse is on cabin, driver side next to the foot rest.
Neal376 had the Fuse pulled & it became a RWD, he was runinng for several month no problem until spin into an accident.
Here are the photos from his old post. where he made a dis-connect switch.
I am just wondering if the car will get damaged doing WOT dyno on RWD
mode. In theory, I think it's OK, I am sure Neal did WOT runs with fuse pulled, any Pioeers out there have done that? Com on, you know you want to dyno your X.
Old Jan 29, 2007 | 08:07 PM
ttrank's Avatar
Grocery getter
Originally Posted by ma_sha1
I am just wondering if it'll get damaged doing WOT dyno on RWD mode.
That was my worry. It can't be good for it.
rookie's Avatar
Doesn't the system kick into RWD after a certain speed? FXs I think it's 18mph it switches to RWD unless it senses slip.
Old Jan 29, 2007 | 08:11 PM
Neal376's Avatar
performance motorsports in Long Island advised againts running in 2WD mode on a dyno...are you sure their are no AWD dynos in maine?? that kind of goes againts rationality
Old Jan 29, 2007 | 08:13 PM
Neal376's Avatar
nah, usually I switch into RWD mode when I'am planning to do alot of WOT
Old Jan 29, 2007 | 08:14 PM
Neal376's Avatar
it just doesnt make any sense that it would be bad to run the car in RWD on the dyno...but than again, that shop advised againts it.
call em up and ask why
http://www.theexperience.com/
Old Jan 29, 2007 | 08:16 PM
Xman's Avatar
There's a website somewhere for RWD and AWD dynos and locations. I had mine dynoed and tuned at Altered Atmosphere. There's also an AWD dyno in Edison, NJ that I've been to.
Old Jan 29, 2007 | 08:25 PM
G-Mony's Avatar
just see where the subaru and n evo's are taking theirs...
i'm taking mine in this week. they dont have experience much experience w/ G35s or even Xs. ...
anybody know what gear it should be dynoed in? 2nd or 3rd? I thought it was 4th but they mentioned it would be too 'tall'..whatvr that means.
