Calling all G's with m45 rims
Old Feb 6, 2007 | 10:13 AM
dunglan7's Avatar
Your theory sounds right about why the m45 car don't have the OEM brembo kit. I just like the m45 wheels a whole lot more than the g35 coupe wheels. Thank for the input though.
Originally Posted by Jeff92se
My suggestion is to look at a M45 with the sport wheels and note the type of clearances it has from the oem brakes. Or have someone take a picture of their wheel to oem caliper clearance. If there isn't at least another 4-5" of clearance, you will have a hard time having them clear.
But because these wheels use a 50mm offset and because the M series was never offered with the wide arsed 4 piston brembos, I'll say no, they won't fit.
IMHO using a spacer wide enough to clear brembos isn't a wise thing to do. They would have to be way long, requiring new studs at least. Also, the spoke design is anther factor for bbk clearance, not just the offsets.
If you want a bbk and if you really want an oem wheel that clears, I'd try to sell/trade for the 19" Coupe wheels. They "should" clear with no spacers and are a TON lighter. IMHO a much cleaner/safer solution.
Old Feb 6, 2007 | 11:27 AM
G35m@'s Avatar
Originally Posted by jovo517
i have 10mm on a 350 drop and its pretty close to the fender anything more than that i think it will rub
Are you running spacers in front and back or 10mm front only? THANKS!
Old Feb 6, 2007 | 12:31 PM
ttrank's Avatar
Grocery getter
Originally Posted by dunglan7
I was thinking about doing this but I just wanted to see if there were any other opitions.
What you might try is getting a caliper template from one of the other 4-pot kits (like racingbrake or AP or stoptech) and seeing how much of a spacer you would need. If it's ~10-15mm and you have the room that would be ok IMO.
Old Feb 6, 2007 | 02:19 PM
cometohell's Avatar
Does m45 rims fits g without bbks?? can anybody post some pics.....
Old Feb 6, 2007 | 02:28 PM
Jeff92se's Avatar
Red Card Crew
No, no they don't
https://g35driver.com/forums/showpos...04&postcount=2
https://g35driver.com/forums/showpos...61&postcount=4
https://g35driver.com/forums/showpos...05&postcount=6
https://g35driver.com/forums/showpos...2&postcount=13
Old Feb 6, 2007 | 02:34 PM
ttrank's Avatar
Grocery getter
No, no they don't
But will with a spacer.
Old Feb 6, 2007 | 02:37 PM
Jeff92se's Avatar
Red Card Crew
You're not sensing the FORCE of my sarcasm
Old Feb 6, 2007 | 07:31 PM
VQ Hotness's Avatar
WhY are theses all my post on this thread?
Old Feb 6, 2007 | 07:32 PM
Jeff92se's Avatar
Red Card Crew
YOU'RE not sensing the FORCE of my sarcasm in my post.
Old Feb 12, 2007 | 10:29 PM
G35m@'s Avatar
OK - sorry to bring this back up again, but looking for a difinitive answer. I know that the front needs 5MM spacers to run the M45 wheels, BUT what spacer set-up will fill out the front and back the best??
VQ Hot - What are you running???
Old Feb 13, 2007 | 12:22 AM
VQ Hotness's Avatar
I was running 5mm all around but sense Ive lowered my car i had to ditch the 5mm in the rear due to rubbing.. I need to get my fenders rolled .
Heres an old pic from a little over a year ago with 5mm spacer on the rear.
Old Feb 13, 2007 | 10:43 AM
dunglan7's Avatar
Dang VQ your back looks like it needs a alignment bad. But what springs did you drop them on? I think Tien's right. I dropped mines on 350z and did not use spacers in the back. No rubbing or any issues so far.
Old Feb 13, 2007 | 11:30 AM
FenixL1P's Avatar
i'm on 350z springs and with 5 mm spacers and i don't rub even when loaded....
Old Feb 13, 2007 | 11:34 AM
VQ Hotness's Avatar
Im fully droped on coilovers. I think that pic might of been on stock ride Hight
Old Mar 15, 2007 | 04:22 PM
  #30
xhova's Avatar
Post more pics
Dude post pictures of your car with those M35 rims on it I am thinking of getting the,, I think they are hot!!!
