Would You Rather??
Originally Posted by Gdup35sedan
did you hit up Kenny(AutoMotiveMods)??? He got the wheels to me quick and easy with great customer service.
-GP-
-GP-
i had them ordered from DNJ wheels i believe and they were screwing me around but this was before they were available anywhere else and i got p*ssed off and told them screw it give me a refund.
i decided not to get any wheels anymore, im gonna give the G to my little sister and im goin for either the M45 or the new Range Rover
20x9 with a +35 wont fit in the front. You'd need a +40 or higher and youd have to run some mad negative camber up front so they dont rub.
For the 19's, if you're only dropped on Z springs, i'd suggest going with 245/35/19 and 265/35 or 275/35/19 in the rear to fill up the fender gap.
-GP-
-GP-
20x9 +35 will work in the front as along as your not dropped. It'll be right at the fenderline, if not a few mm over. If you drop, then it'll rub really bad unless you get some negative camber and roll the fenders.
^True...but...most people considering 20's will probably wind up getting a drop.
Better to think it out and get the right size first, in anticipation for doing what you say you won't do today.....the mod bug always bites
