How to change auto trans fluid?
Old Mar 8, 2007 | 12:45 PM
sliderg35's Avatar
OK, I already seached the DIY section - no luck. Does anyone have info on how to change the fluid?
Old Mar 8, 2007 | 05:14 PM
Mmagic76's Avatar
There's a bolt underneath the car, I think it's in the middle b/t the two front wheels closer to the passenger wheel. Unscrew, drain, and refill up top under the hood. 4-5 quarts is required for a drain and fill.
Old Mar 8, 2007 | 06:21 PM
sliderg35's Avatar
Sounds simple enough - thanks!
Old Mar 8, 2007 | 06:24 PM
IP05G35's Avatar
Where do you refill underneath the hood? I don't see a dipstick tube?
Old Mar 8, 2007 | 08:07 PM
Mmagic76's Avatar
b/t the back of the engine and firewall, there is a small tube, a bolt holds the cap on, you have to take the bolt off first.
Old Mar 9, 2007 | 10:19 AM
ttrank's Avatar
Grocery getter
Take some pics when you do it so the next guy won't have to ask again.
Old Mar 9, 2007 | 02:09 PM
StarChamp's Avatar
Sounds simple, but it's not if you want to do it right. You'll never get the fluid out of the torque converter by draining it that way, it needs to be flushed like the cooling system. Doing a gravity drain is fine if you're just changing the fluid because you want to, but if the car really needs a fluid change, you're better off paying to have it done properly. That's most likely why you didn't find much DIY info on it.
Old Mar 9, 2007 | 03:08 PM
Mmagic76's Avatar
Most dealers say a drain and fill is sufficient vs a complete flush. If your fluid is really dirty, I would just do the drain/fill yourself twice (2nd time after driving for a while to mix the old/new fluid).
Old Mar 10, 2007 | 10:46 AM
Noremac's Avatar
When in doubt, read the FSM!! See this post for the 2004 instructions (I doubt they have changed):
https://g35driver.com/forums/showpos...3&postcount=33
Old Mar 10, 2007 | 02:41 PM
yuanchen's Avatar
Yes picture perferred
so someone doing it post some picture thanks
Old Mar 10, 2007 | 02:47 PM
nanjay's Avatar
even draining and filling the trans fluid twice wont replace all fluids to be new.
you figure doing it three times and by that time the cost of good fluid and your time starts to add up, also your not still sure if its completely new fluid.
just take it to a shop and have it power flushed once and your done
-Jay
Old Mar 10, 2007 | 02:58 PM
nghiars's Avatar
if u dont have too many miles then u probably dont need to do a complete flush.
Old Mar 10, 2007 | 06:14 PM
jimNC's Avatar
-Jay
I think the strategy is just to change it at more frequent intervals when not doing a flush, which I think is fine, over the life of the car. I flush it myself, but I can see doing this too.
Old Mar 10, 2007 | 09:35 PM
andyharada's Avatar
Where were you able to find the special ATF Infiniti recommends and how much?
Old Mar 11, 2007 | 08:51 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Buy it at the dealer... prices aren't bad.
BTW don't use the other exotic fluids out there.
The Nissan fluid is synthetic & designed for the AT.
