Map light trim removal
I've posted this before, still don't understand how to remove the map light trim. I have the service manual which shows two clips at the rear side of the trim. I have tried to insert putty knives in to depress the clips with no success. I'm worried about damaging the headliner.
Is there a trick to this removal?
Thanks for any help,
Mark
Mark
There are metal rings on some of the housing standoffs that line up to holes in the headliner. I think dropping the headliner down at the moon roof is the only way to get the clips off cleanly.
are you trying to remove the headliner?
if so - i removed the blinds and their mounts first. I removed the run-rubber from the sun roof and just yanked (also removed the oh-**** handles )
