Taking a long break from the G
In a few days I'll be out of the country for 1 month and staying in Shanghai, China (with my wife and her family). I'm going to miss the G dearly but I'd like to know what is needed to be done prior to my departure to ensure the car will be in solid driveable condition when I come back. The G will be parked outside at my parents' driveway and will be car-covered. More than likely the car will not even be turned on, so should I need to disconnect the battery? Overfill the air in the tires? Fill the gas entirely or halfway (it's currently less than 1/4)? Any feedback is much appreciated, TIA
drain the engine oil put some fuel stabilizer in the gas tank its only a month so you wont have to do as much as if you stored it for 6-8 months like i have to when i go on deployments
if no one starts her..you could always unplug the coil
before starting her..30 seconds would suffice
battery disconnect is always a good idea. dry gas when you come back
but don't think you need it for 30 sit
Originally Posted by strife
Just get your parents to fire up the engine once a week for 5 mins, you'll be fine....that's what I pretty much did last Dec-Jan
Jiggerjuice
Oct 5, 2015 02:33 PM
