mounting tape
Re: mounting tape
Usually warming the surface gently with a hairdryer helps. The remainder can be rubbed off with your finger and residue can be removed with 'Goo Gone' or even WD 40.
Re: mounting tape
The WD 40 should be safe. I've heard that others use Goo Gone. If you use the hairdryer, warm GENTLY and evenly around the area. Remember to clean after with car wash soap and wax ASAP.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
