J Matic replacement ATF
Old May 16, 2007 | 10:25 PM
IP05G35's Avatar
Castrol Import ATF
http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
Old May 16, 2007 | 10:28 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
there is NO replacement for Nissan J Matic ATF. if you want to use something else then by all means be my guest but dont cry when you have to replace your $4000 tranny.
-GP-
Old May 16, 2007 | 10:40 PM
IP05G35's Avatar
Let me ask you this... what oil do you use in your G35 because the manual calls for using mineral/dino oils only... I supposed my engine will need to be replaced soon because I use Amsoil right? There is nothing special about Nissan J Matic fluid... it meets certain specs and is a synthetic blend... this Castrol ATF meets or exceeds the same specs and will work fine and is much cheaper... paying $10 a quart for a synthetic blend of ATF (Nissan J Matic) is ridiculous, Nissan is getting over on the consumer.
Old May 16, 2007 | 10:43 PM
an Engine and automatic Transmission are two completely different machines. I use Mobil 1 and you use Amsoil, doesnt matter, oil is oil. Like i said, you can go ahead and use it. But the J Matic isnt all that expensive as everyone seems to think. I'll take the piece of mind with using what is recommended. The castrol you posted is the first i've ever seen of any company saying they've found a J Matic replacement.
-GP-
Old May 16, 2007 | 10:46 PM
avs007's Avatar
-GP-
If the Castrol Import fluid says it meets or exceeds the specifications of Nissan Matic-J, than Nissan cannot deny you warranty coverage should the tranny happen to blow-up. They legally cannot require you to use Nissan branded parts vs a different branded equivalent, unless they supply said parts for free. This is explicit.
So no crying necessary, because if something happens to your $4000 tranny, Nissan will be replacing it for you if you are under warranty.
I wonder where you can buy this Castrol stuff. Is it special order only? I've never seen it anywhere around here.
Old May 16, 2007 | 10:52 PM
IP05G35's Avatar
It's available at Kragen/Checkers/Schucks.
Old May 17, 2007 | 12:19 AM
02themax's Avatar
What about the Mobil ATF, Is that safe to use?
Old May 17, 2007 | 01:58 AM
Jeff92se's Avatar
Red Card Crew
Why are you asking the same basic question again?
j matic specs/alternatives:
https://g35driver.com/forums/showthr...o+tranny+fluid
From your own thread:
https://g35driver.com/forums/showthr...hlight=j-matic
Old May 17, 2007 | 02:10 AM
IP05G35's Avatar
This is a new fluid Castrol just came out with...
Old May 17, 2007 | 02:12 AM
Jeff92se's Avatar
Red Card Crew
Cool. Always good to have alternatives. Seems to spec out okay
Old May 17, 2007 | 08:23 AM
Neal376's Avatar
dammit...and i just fille with jmatic too
Old May 17, 2007 | 09:04 AM
DieselX's Avatar
I'm broke and this seems like a good replacement. I'll be the test dummy soon, if I can get it around here.
Old May 17, 2007 | 01:49 PM
ttrank's Avatar
Grocery getter
No the dealer won't deny your claim but they might make it a lot harder on you.
What is the cost of peace of mind?
Old May 17, 2007 | 02:50 PM
g35rcr's Avatar
This is true, they will make it near impossible for you to get it replaced...but hey do whatever its your car...you could put spinners and a wing for all i care
Old May 17, 2007 | 04:25 PM
joedaddy1's Avatar
no Mobil ATF is way too thin.. it's really bad..
it F ed up TWO trannies on my old car..
