Blacked Out/Halo/Projector Conversion
Old May 27, 2007 | 05:09 AM
JOKER's Avatar
CLUB MODERATOR
Looks really nice
Old May 27, 2007 | 05:32 AM
perry05G35's Avatar
^ That's what I meant the base for the D2S so you could use our factory D2R bulbs with the projectors?
Old May 27, 2007 | 07:15 AM
jimmyc13's Avatar
Your car is lookin' hot KHSONIC! First time I've seen picts of your car....very clean setup w/ your rims & NISMO kit. Lights look great...keep up the good work.
Old May 27, 2007 | 09:55 AM
khsonic03's Avatar
Thanks for the comments guys. I'll answer a couple of the questions. I didn't do quads because of a $$ issue. I just bought my first house right in the middle of this project, which sucked alot of $$ out of me. That is also the same reason I went TSX vs. S2K. The output is great. I have Philips Ultinons in there as well. I absolutely love the projectors vs. the standard lights. Amazing, especially w/the Ultinons.
A word to anyone installing halos. First, DO NOT extend the wires from the inverter to the actual halo. I did this so I could mount the inverters in a particular spot. I used heavier gauge wire and soldered all connections. First problem I had was that the bottom ones wouldn't light up all the way, now my top ones just went out because the wires burnt up. After a little research, I found that most people have the same problems when increasing the length of those wires.
I wired the halos up using a relay. I spliced into the cigarette lighter on the drivers side, put a switch under the dash, and ran it over to a relay in the battery compartment. This way, the halos always come on when in ACC or ON, but I can turn them off during that time if I want. I also don't have to worry about leaving them on by accident, because they turn off when the car goes off.
The shroud is a metal chrome 2" toilet flange over 3" abs pipe, and attached to 1/8" abs sheet. I painted it all black to match the rest of the headlight fixture. The D2S wiring is all the same, the only change I had to make was to splice a different female connecter on for the ground. Overall, it came out great, with the exception of the problems I am having with the halos. I personally think it looks factory quality, even up close. When the halos were working, it looked sick. I am waiting to get higher powered inverters from AAC. Jason has been very helpful during this process.
Old May 27, 2007 | 10:49 AM
Mark350GT's Avatar
wow very nice. love the look of you sedan
Old May 27, 2007 | 08:29 PM
RocketG35's Avatar
Why do I bother to DIY???
Awesome job man! Take some shots in the daylight please! I'm still sitting on my TSX projectors...one of these days.
Old May 28, 2007 | 02:55 AM
chinaman_87's Avatar
thanks for the info! I just recieved my abs sheets in the mail on saturday and I also have those flanges. I bought them when I first did the project but couldn't come up with a way to make them look the way I wanted. Great job!
One more thing what did you use to cut your abs for the circle and just in general?
Old May 28, 2007 | 09:09 AM
khsonic03's Avatar
I used a dremel with a cutting wheel.
Old May 29, 2007 | 02:42 PM
ttrank's Avatar
Grocery getter
It's funny, those shrouds look a lot like my cut down GS430 shrouds and I bet the cost you 1/4 of the price.
Old May 29, 2007 | 03:24 PM
dyenboy's Avatar
Registered
tat is dam clean..need some nite time pics tho
Old May 29, 2007 | 04:48 PM
Wicked_limitz's Avatar
that looks sick.
Old May 29, 2007 | 07:10 PM
ricerboi's Avatar
your car looks very nice. The hid + halo job looks incredble. do you have pictures at night time with the hid's on, also with them shining on something. I plan to do the same when i get my g35.
Old May 29, 2007 | 10:45 PM
khsonic03's Avatar
I'll definitely get you guys some nighttime pics once I get this halo thing corrected. Hopefully it will be all set this coming weekend, unless any of the halos burned out from me extending the wires...
Old May 30, 2007 | 12:05 AM
ttrank's Avatar
Grocery getter
They should be ok.
Let me know what Justin had for higher power inverters. It would be a nice option in case I ever have problems in the future.
Old May 30, 2007 | 04:53 AM
  #30
Blue_Batmobile's Avatar
Official Sponsor of the Florida G35 Club
Love it!
Bat™
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mbe32
Interior
Oct 1, 2015 09:47 AM
Vanessarino
Audio/Video/Electronics
Sep 12, 2015 10:48 AM
