G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Thats it I've had it! (https://g35driver.com/forums/g35-sedan-v35-2003-06/160261-thats-ive-had.html)
Neal376 Jun 2, 2007 03:03 AM
My exhaust is useless
I have Fast Intentions HF Cats, 05 midpipe and HKS Rear muffler
and it all counts for NOTHING!
every exhaust piece I have added has only made my G slower.
so not only is my car loud. raspy and embarrasing, its slower than a 5.5 gen maxima (which is what I found out just last night)
im returning everything back to stock. Im assuming the ECU has just gone crazy and has retarded my timing. Im not gonna fork over another G to tune this stupid ECU, its a dam money pit and its only gonna stop if I quit now.
http://i155.photobucket.com/albums/s...h_CIMG0872.jpg
http://i155.photobucket.com/albums/s...h_CIMG0873.jpg
ricerboi Jun 2, 2007 03:07 AM
seems to me your not even gunning it...?
the exhaust sounds very nice, imo
you try disconnect the batter for 10 mins and reconnecting it?
steve21 Jun 2, 2007 03:07 AM
Ouch!
da mayor Jun 2, 2007 03:34 AM
no theres rasp but I think its the cats...I have no rasp from my set up and neals just venting cuz I pull on him very easy
ttrank Jun 2, 2007 03:37 AM
If you are not happy, go back to what you like.
skeleton_cru Jun 2, 2007 03:41 AM
You're obviously not happy with that set-up so go with what will make you happy.
da mayor Jun 2, 2007 03:42 AM
I'm tellin him its his crappy test pipes but he likes my set up sound.
I'm hoping that rasp will go away I heard that same rasp on another sedan and it was those hf cats
Neal376 Jun 2, 2007 03:45 AM
you saw mike? i couldnt pull away-thats horse ****!!! when you first got your sedan i was pulling on you! something is def wroung!
im gonna pull my entire exhaust off, check for leaks and re-seal everything. if thats no good, than it is back to stock
dofu Jun 2, 2007 03:45 AM
An exhaust alone will do nothing but make noise... instead, try a spacer, work on your suspension... you'll be happier.
Neal376 Jun 2, 2007 03:48 AM
i got a crawford plenum and intake, those fared much better.
my H/F cat felt very nice the night i put it on. every day after that it felt slower than stock.
Neal376 Jun 2, 2007 03:52 AM
crappy test piprd?s
400 bucks for hf cats, 300 for plenum and 200 for intake = slower than 5.5 gen maxima + 16mpg + loud as hell = driver pissed off
dofu Jun 2, 2007 03:54 AM
Also, the more you build your car whether with bolt-ons or rebuilding the motor, the more you are losing bottom end and gaining top end (most of the time). So the gains you feel and use will depend on when you (or your tranny) are shifting.
G35Papa Jun 2, 2007 04:23 AM
I too went through different variations of a put together exhaust as well. Coupe middy, HKS rear, Crawford CATs, Megan Racing Y pipe.
I lost a considerably noticable amount of bottom end when I put the Y pipe on and got an annoying rasp (due to 3 inch outlet dumping into a 2.5 inch inlet)..got ride of the Y. CATs gave me a gain on both top and bottom end. (more noticable on top end) but basically only on the top end since I coupled them with the Y. I also had a small rasp from time to time with those as well and I even got all new gaskets from the header outlets all the way out the back.
Sold the CATs and now have whats left.
I don't think your rasp will go away with new gaskets but it's worth a try I guess. The gaskets on the top side of the CATs are the most expensive. The rest are fairly inexpensive.
I am now opting for a full cat back system and will most likely be done with exhaust from there.
I feel your pain Neal as I went through the same. In the end, all these aftermarket exhaust parts don't always match up.
Try just the middy and the HKS, reset the ECU and drive it like you stole it so the ECU learns the new flow patterns.
Good luck
G SEDAN Jun 2, 2007 05:12 AM
:biggthumpup: dibs on HKS neal and papa!!! HAHAHAHAH!
dofu Jun 2, 2007 05:32 AM
I don't understand why everyone wants to reset the ECU... it'll retune itself to your new mods automatically whether you reset it or not.
© 2026 MH Sub I, LLC dba Internet Brands
