Factory spoiler loose
Old Jul 25, 2007 | 11:33 AM
RADIOGUY21's Avatar
I have a '05 sedan with the factory installed spoiler. Ive noticed that the right side of the spoiler is loose where it bolts to the trunk lid. I can actually move the spoiler up and down a small amount on the right side, but the left side is tight. I would like to avoid taking it to the dealer because im sure its 2 nuts or bolts holding it in that just need to be tightened down. I cant seem to find any access holes to the fasteners. Has anyone installed an OEM spoiler or have had this problem before? I just downloaded the FSM and its not too helpful with spoiler removal/installation. Do I need to remove something on the underside of the trunk lid to get to the spoiler fasterners? Thanks!
Old Jul 25, 2007 | 11:45 AM
G SEDAN's Avatar
open your trunk and look directly right under it. I believe mine (04) is held by 1 (10mm) bolt on each side and the rest is all 3m double sided tape.
Old Jul 25, 2007 | 01:07 PM
lexusk8's Avatar
The mounting bolts for the spoiler may be hidden underneath the trunk lining which are held by several plastic clips. You'd need to use a flathead driver to pop the clips off and get to the mounting bolts.
Old Jul 25, 2007 | 01:29 PM
RADIOGUY21's Avatar
okay thanks alot, i will take a better look at it tonight.
Old Jul 25, 2007 | 02:53 PM
RADIOGUY21's Avatar
wow i am blind, I didnt even notice the trunk liner. Thanks again for your replies.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
dseet
Oct 11, 2015 12:40 AM
TurTLe*
Sep 29, 2015 01:43 PM
