Revised springs and d-spec settings?
Old Jul 27, 2007 | 12:19 AM
ashish's Avatar
I'm trying to adjust my d-specs to get a close to stock feel as when i had my original springs and shocks (non-sport). just wanted to know what you guys with revised springs have used. I tried 5 turns from stiff front and back and it was way too floaty and bouncy. 4 turns from stiff front and rear was way too stiff.
I'm currently using 350/coupe springs and new d-specs for a 350
Old Jul 27, 2007 | 10:45 AM
obender66's Avatar
It is between 4 and 5 indeed, but your tire model and tire pressure would matter too. 1/4 turn make difference too, so keep playing with it, you are in the right range. I am at 4, but I prefer stiffer setting.
Try tire pressures 30-36 psi cold
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
reaper76
Aug 5, 2015 10:13 AM
xplosive1
Aug 1, 2015 03:01 AM
Scredeur4
Jul 17, 2015 06:30 AM
