Felt Cloth Tape for Rattle fix?
Old Aug 10, 2007 | 10:47 AM
ajg35's Avatar
I've searched the forum but haven't had much luck. I'm trying to find some felt cloth tape to take care of the typical window and dash creak TSB's. Anyone hear know of a place that sells decent quality felt tape? My dealer told me that that the infiniti stuff is cheap and that I'd be better off buying it elsewhere.
Old Aug 10, 2007 | 10:52 AM
chilibowl's Avatar
Home Depot? Lowes?
Old Aug 10, 2007 | 12:02 PM
ajg35's Avatar
Originally Posted by chilibowl
Home Depot? Lowes?
I've checked those places along with a few craft stores with no luck. I was hoping someone would post a link to an online store.
Old Aug 10, 2007 | 12:05 PM
izmir41500's Avatar
G35driver Addict
really? shouldn't be hard to find at hobby lobby or michael's
Old Aug 10, 2007 | 12:11 PM
twitch's Avatar
I don't have any online links but I bought a felt pad from Walmart. It was in the hardware section where they sell the protective pads to put on furniture legs and so forth.
I used this for the rear view mirror and it worked ok.
Old Aug 10, 2007 | 12:16 PM
GreenGoblin's Avatar
The goblin resurrection
they sell double sided tape at like pep boys
Old Aug 10, 2007 | 01:22 PM
jimmyc13's Avatar
Yes they do...home depot DOES. It's not felt "Tape".....go buy a small package of the felt rectangles that you can custom cut, that are used for putting on the feet of furniture to protect hardwood floors...that's what I used & it worked.
Old Aug 10, 2007 | 01:24 PM
eric300zx's Avatar
sorry to butt in but where do you guys apply the tape to fix the creaks?
Old Aug 10, 2007 | 03:16 PM
chobble19's Avatar
i ordered a roll of it from a local dealer
Old Aug 10, 2007 | 03:27 PM
chobble19's Avatar
heres the part # 68239-13E00
Old Aug 10, 2007 | 05:13 PM
twitch's Avatar
Wherever applicable according to the TSB (Technical Service Bulletin) for your year/model.
For example the 2004 Coupe information is here
http://www.infinitihelp.com/Bulletin...upe/2004/1.htm
If you have a coupe select the year from the links across the top of the page. If you have a sedan select the link to the left.
Old Aug 11, 2007 | 08:15 PM
OCG35's Avatar
I take it your car is out of warranty... if not, Infiniti should do it free, they did mine (window TSB).
Otherwise, just go to the dealer service department and ask a tech (or parts guy) directly if they will give you some - they gave me some thin rubber tape that works great for center consol plastic on plastic buzz/vibration. I’m sure they’d give you the felt pads too… if not they don’t care about you as a customer… The materials cost them virtually nothing (for the amount you need).
Edit: the "rubber tape" isn’t really tape, it's super thin rubber (thinner than a credit card) that has adhesive on the back. Perfect for vibration rattle & buzzes.
Old Aug 11, 2007 | 08:55 PM
killerlexus's Avatar
felt tape is used around the window and door for the home, it comes in a roll, maybe you didnt look in the right place at homedepot.
Old Aug 11, 2007 | 09:27 PM
OCG35's Avatar
you don't really need a roll for the window TSB... just a few short pieces.
Old Aug 12, 2007 | 04:03 AM
STOOF's Avatar
i had the rattles on my pass door. i couldnt find the felt tape either. i just used a couple pieces of duct tape on the flanges. no more rattles.
you could stick anything on there. anything to stop the plastics from hitting each other.
