Shell Spirax 75W90 in Transmission
Old Sep 11, 2007 | 09:17 PM
maxpusher's Avatar
20 Year Member
Hello,
I am changing my 6spd transmission and differential oil. I see some people are using the Shell Spirax 75W90 synthetic gear oil in transmission and differential oil. This oil is rated GL-5 which isn't compatible with the 6spd transmission (GL-4 needed). However, there has been some talk that the Shell gear oil is copper friendly. To those who are using this product, how does the transmission feel compared to the OEM fluid? Is this safe for our transmission? How many miles have you put with this fluid?
Also, do all G35's have LSDs in the differential? Is any friction additive needed?
I would like to hear your opinions. Thanks.
Old Sep 11, 2007 | 10:41 PM
canucklehead's Avatar
i just went through all this. all 6spd models have the LSD diff.
use the GL-4 in the tranny, not an oil that claims to be both. use GL-5 in the diff.
i used pennzoil synthetic gear and tranny oil, with no additional friction modifier for the diff.
Old Sep 11, 2007 | 11:13 PM
maxpusher's Avatar
20 Year Member
Thanks for your reply. Will Royal Purple Max Gear 75w90 work? On there website it says it is both GL-4 and GL-5 compatible. Anyone who is using it want to confirm?
Old Sep 11, 2007 | 11:35 PM
GreenGoblin's Avatar
The goblin resurrection
iam getting ready to change mine as well i am thinking about using royal purple as well
Old Sep 12, 2007 | 01:36 PM
Pska's Avatar
could someone please link up a GL-4 product? I want to change mine before winter comes and I cannot afford to screw up a tranny!
Old Sep 12, 2007 | 02:12 PM
bythabay's Avatar
https://www.amsoil.com/storefront/mtg.aspx
Old Sep 12, 2007 | 04:03 PM
http://www.pzlqs.com/Tech/Pdsheet/Do...E75W90GL-4.PDF
Pennzoil Synthetic GL-4...
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
