ratcheting sound coming from new drilled/slotted rotors and pads
Old Oct 4, 2007 | 12:24 PM
gtrecinco's Avatar
Just installed stillen drilled / slotted rotors and hawk pads, they are braking great but when I am driving next to barrier i hear a slight noise kind of like when we put cards in our bike spokes.... is this inhearent to these rotors? or did i install wrong ?
Old Oct 4, 2007 | 12:45 PM
TIRE_SMOKE96's Avatar
did you have them ground before installing? Meaning did you take them to a brake shop and have them grind the surface of the new rotors so that they are a true flat surface. Im thinking that every time the rotor turns a hich spot rubs on the brake pad. It should go away after a while, but I would have it fixed right away. Who wants there G to sound like a bike with the cards in the spokes? LOL
Also did you install the rotors so the vents on the edge will force the brake dust out.
Old Oct 4, 2007 | 02:14 PM
gtrecinco's Avatar
thanks for reply, I did not know i had to take to have them turned ? also did not see anything on installing them with slots facing a certain way ? I followed the directions from a post on here.
Old Oct 4, 2007 | 03:46 PM
When you look between the two surfaces of the rotors you will see those slots. They have to be facing so the rotors will push the air outward not inward.
Also double check that your wheels are not rubbing the calipers in any way.
Old Oct 4, 2007 | 04:01 PM
snavematt's Avatar
just a sedan
my rear stock driverside rear does that, had it fixed at the dealer twice, heatshield I think they said was loose. One more time and I will call out the lemon law
Old Oct 4, 2007 | 04:07 PM
G35Papa's Avatar
+1
It's most likely the dust shield on the backside of the rotor (behind it). I recommend that they be removed when going aftermarket. I removed mine after I started hearing some noise.
You don't need to have the rotors grinded but you do need to do a break in cycle to bed the brake pads onto the new rotors.
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Oct 4, 2007 | 04:24 PM
MrBillMartin's Avatar
some times good pads make noise. ya ever hear a race cars brakes? im putting hawk hps on when i get my rotors in the mail any day now.
Old Oct 4, 2007 | 04:26 PM
snavematt's Avatar
just a sedan
Originally Posted by G35papa
+1
It's most likely the heat shield on the backside of the rotor (behind it). I recommend that they be removed when going aftermarket. I removed mine after I started hearing some noise.
can I remove the shields from the OEMs and not have rotor complications?
Old Oct 4, 2007 | 05:10 PM
G35Papa's Avatar
It's actually a dust shield (edited my post), so yes, you can remove them but if they aren't making any noise/complications I would just leave them alone.
The fronts are the only ones you would need to remove. The rears are a b1tch to get off. I winded up just cutting them down when putting on my BBK.
Old Oct 4, 2007 | 05:15 PM
gtrecinco's Avatar
I remember the slots between rotors... so is there a right and left to the rotors? how could they be on wrong ?
Old Oct 4, 2007 | 05:27 PM
G35Papa's Avatar
the "slots" on the rotor need to be facing forward.
Below, you can see the drilled "slots" are facing forward \
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
MsFitFern
Aug 9, 2015 02:58 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
