SEDAN guys I need some wheels and tires
Old Oct 10, 2007 | 01:35 PM
68_GT's Avatar
and longer wheels studs ?
Old Oct 10, 2007 | 01:49 PM
ashish's Avatar
Yup, those are a must. They come with the spacers. You'll have to change the original wheel studs to the new extended wheel studs.
Old Oct 10, 2007 | 02:33 PM
FlyingLumpia's Avatar
VQ hotness used 5mm without longer studs.
Old Oct 10, 2007 | 02:59 PM
ttrank's Avatar
Grocery getter
Even that is pushing it. IMO I would never go more than 3mm without getting longer studs. Chico and I spoke about this a while back and I think he feels the same.
Old Oct 10, 2007 | 04:16 PM
VQ Hotness's Avatar
I did run with 5mm spacers without longer studs for 2 or 3 month. I do not advise anyone doing this b/c it is extremly dangerous. I was lucky and caught it b4 my rims fell off and ordered a kit that came with longer studs. A friend of mine did the same thing and was only going to run 5mm spacers for a few weeks till he ordered longer studds and less then a week in his front rim fell off while he was making a turn. He was going under 5-10mph so their was only cosmetic damages.
SO GET EXTENDED STUDS! Its worth it
Old Oct 10, 2007 | 04:41 PM
NathanJax's Avatar
..... I WIN .....
So with those m45 rims, would you advise the 5mm or 10mm spacers? or 5 up front, 10 in rear (like others mentioned) Only reason I ask is because your car is the only car I've seen them on so far. These will be the rims I get !!
Old Oct 10, 2007 | 04:45 PM
(>")> G35's Avatar
I'd go 15mm spacers if you want an aggressive offset, plus you can use spacers with the built in studs.
Old Oct 10, 2007 | 05:49 PM
VQ Hotness's Avatar
I would personally go 10mm.. I have 15mm spacers right now with my current rims and have had problems with the way they bolt on to the hub.
Old Oct 11, 2007 | 08:17 AM
wreckeds2k's Avatar
I have got a lot of info from this thread.. thanks guys, the studs will be an easy change but where will I get the spacers??
Old Oct 11, 2007 | 08:23 AM
NathanJax's Avatar
..... I WIN .....
I kinda had the same question. But I gather from this, they are sold together.
Old Oct 11, 2007 | 02:19 PM
ashish's Avatar
I got my extended studs with the spacers, from what i know they normally come with the spacers. Try going with the bigger companies like Ichiba, H&R, Eibach, Project Kics (they all come with the extended bolts)
bTanz
Oct 15, 2015 02:31 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
