how much lower should i do?
Old Oct 11, 2007 | 04:48 PM
ch5329jack's Avatar
im new here, just got mai 03 G35 sedan 5AT, thinking of putting a lower spring and a muffler..
i heard Tein S-type and HKS sprots exhaust works pretty good on the G35
any suggestion???
thx
Old Oct 11, 2007 | 04:54 PM
Jeff92se's Avatar
Red Card Crew
Question is "are you willing to buy all the camber correction kits required if yo lower more than about 1")
Old Oct 11, 2007 | 04:57 PM
G35Papa's Avatar
HKS ftw!
Slam it and buy some camber kits...or save money for tires
Old Oct 11, 2007 | 04:58 PM
UnluckyCharms's Avatar
Question is "do you really just want A muffler and A spring?????"
Old Oct 11, 2007 | 05:09 PM
az1anbeethoven's Avatar
HKS sounds really good!!...
Old Oct 11, 2007 | 05:22 PM
93 til Infiniti's Avatar
If you dont want to deal with the camber issues, and you wanna drop it with exhaust, then I would go H-techs with the HKS. With S-techs youll have to deal with all the suspension issues.
Im very happy with my H-techs and havent had any issues. Its not slammed, but i do have staggered 19" wheels too. Check the link in my sig to see the drop.
Old Oct 11, 2007 | 05:49 PM
G35Papa's Avatar
Tein Basic coilovers or CS if you want a softer ride. You can go up and down as you please
Old Oct 11, 2007 | 09:35 PM
ch5329jack's Avatar
ill go w/ H-tech then....
dun really know wat "camber" realli is....
anyone cn explain?
>< thx..
Old Oct 11, 2007 | 09:38 PM
jimmykce1's Avatar
I have 350z springs in front and coupe springs in the rear. The spring rates matches my stock sport suspension springs and rides about the same. However, it handles a lot better. I did have to get front camber kit although.
Old Oct 11, 2007 | 10:08 PM
03Sg35's Avatar
I have the 350z/coupe combo and its sits very nice and handles better.
Old Oct 11, 2007 | 10:46 PM
G35Papa's Avatar
When you lower a car, the weight and stress put on the suspension pushes the tops of the tires inward.
Looking from the back of the car the tires would sit like this / \
A camber kit allows you to adjust the camber angles made by lowering it so you can get back to stock (or as close as possible). This also prevents the tires from wearing in an uneven manner.
Ever see those Civics that are super low? /___\
http://en.wikipedia.org/wiki/Camber_angle
Old Oct 12, 2007 | 01:45 AM
ch5329jack's Avatar
would H-tech gives a good handling??
if not...what should i do to get a good handling on my 03 G35 5AT??
help meeh out.!
Old Oct 12, 2007 | 01:53 AM
CRASH-a-LAC's Avatar
with this combo,,how low will it drop a 04 sedan?.....just curious.
Old Oct 12, 2007 | 11:44 AM
WILLIE BEANS's Avatar
Lets Say You Have A Setup Your Going To Add To Your Car
And It Drops You Over 2"
Do You Really Need A Camber Kit ..??
Reason I Ask Is :
Im About To Drop Over 2"
=o =)
