newbie question about the off set............
Old Nov 14, 2007 | 07:14 PM
Tloc05's Avatar
Just can't seem to find info on the off set of my 04 sedan's wheels. They are 17's. I googled it but can't find infinitis. I want to put some 04 tl 17's on my g for the winter, will they fit if the off set of the tl is 45. Sorry for the dumb question and thanx in advance.
Old Nov 14, 2007 | 07:17 PM
GEE35FX's Avatar
45mm offset will work fine as long as the center bore and bolt circle diameter are okay.
Old Nov 14, 2007 | 07:28 PM
FlyingLumpia's Avatar
+1 Also if you look at the back of your stock wheel, you would see 17x7 and then I think it says offset or something of that nature with a +45 or some number with a +.
Old Nov 14, 2007 | 07:31 PM
az1anbeethoven's Avatar
the TL stock wheels WILL NOT work because the center bore is too small...infiniti's stock center bore is 66.1 and Acura's is 56.1
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
