G35 sedan belt differences?
Old Dec 17, 2007 | 11:31 AM
KapnK's Avatar
My girl's 2003 sedan was built on 5/2002 according to driver's side door jamb. While checking some sites a couple of weeks ago, I noticed some different belt choices according to the build date. On searching through the forums, I've also discovered that in mid-03, they went to electric fans and I assume that is why the belt is different.
Which belt is different? The alternator? Are the a/c belts the same?
Does anyone know the actual belt lengths?
Thanks for the help.
Steve
Old Dec 17, 2007 | 04:35 PM
QuadCam's Avatar
belt should be the same. nissan just replaced the fan drive with an idler pulley on the new cars.
it should be a k060465 (that's a gates part number.)
you may want to verify this though.
Old Dec 17, 2007 | 04:43 PM
KapnK's Avatar
The thing is, I went to Advance auto parts on Saturday and asked for some belts. They had 2(for the alternator one, i believe). I think one was 36.5" and one was 37.5". I don't believe they even carried gates. I've got a couple other parts stores in town, I was just checking it out.
Old Dec 17, 2007 | 05:05 PM
ttrank's Avatar
Grocery getter
That's odd. I thought they were the same size too.
Old Dec 18, 2007 | 08:21 AM
KapnK's Avatar
Ok. I did a little more research last night. It seems that the alt belts are the same @ like 47". The a/c's are different. I'm guessing that the pulley on the compressor are different diameters because one specified from 1/00 to 9/00 with OEM compressor. That would explain the 36.5 and 37.5" belts.
Old Dec 24, 2007 | 04:02 PM
KapnK's Avatar
I swapped the belts yesterday. I wasn't sure about the a/c one so I bought the smaller 36.5" one. I had a 50% chance, right. Worst case, I drive back down to parts store and swap it out for the larger one. It was the smaller one. I just wanted to follow up in case anyone else has the same question.
Old Dec 24, 2007 | 04:55 PM
ttrank's Avatar
Grocery getter
Thanks for letting us know.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
