Door panel removal
Old Dec 19, 2007 | 05:16 PM
blownvert's Avatar
Door panel removal
How do i remove 04 g35x front door panels? Any write ups? Theres rattling coming from passenger side door panel and now my right speaker i think is a loose connection. It sometimes fully works and now past few days it will come on and off. It must be the wires from the speaker and not the speaker harness behind radio.
Old Dec 19, 2007 | 09:59 PM
blownvert's Avatar
anyone?
Old Dec 19, 2007 | 10:30 PM
G35Papa's Avatar
There are 3 screws. One by the interior door lock/opener and two under the door trim piece (under the red circles shown in the pic).
Us a flat head screwdriver to remove the coverings. On the door trim, there is a small slit toward the bottom of the trim, put the screwdriver head in there and twist. It should snap the trim off.
After you remove the 3 screws, grab the handle (where the trim piece is) and pull it towards you. Give it a good tug. Not to hard but with a little bit of effort. Disconnect the lower door light. You're in.
There, thats the best I could do. good luck
Old Dec 19, 2007 | 11:30 PM
psedog's Avatar
Back in SD**
don't forget to disconnect the wiring to your switches before pulling out the panel all the way.
Also i believe there is a metal rod for the door handle that you have to disconnect.
Old Dec 20, 2007 | 06:44 AM
blownvert's Avatar
how do i get to the square door lock/unlock behind it? Do I have to pull that thing off and then the screw is behind it?
Old Dec 20, 2007 | 06:53 AM
35bills's Avatar
That's correct. Use a small head flat screwdriver to "pop" the square cover off that is beside the door lock. The screw is underneath.
Old Dec 20, 2007 | 11:03 AM
blownvert's Avatar
ohhhh i see it, okay. I was thinking the actual thing that moves to lock and unlock, but i saw beside it the square box. i hope its easy to get it back in, its easy to take it out, but its a pain to match up the pin holes to get it back in properly. Havent seen the inside yet.
Old Dec 20, 2007 | 11:42 AM
G35Papa's Avatar
Its very easy to get back in
Old Jan 10, 2008 | 04:01 PM
MIA BlazinVQ's Avatar
brb getting cut
Bump. I need to take off the door panel off of my car to do the reset, but I dont think its the same as the sedans.
Can anyone tell me how to remove the door panel on the coupe (newer interior if it matters) to get to the window motor?
if you could be detailed in the instructions i'd appreciate it.
Old Jan 10, 2008 | 04:33 PM
brb getting cut
anyone? I'd like to do this today before the sun goes down.
Old Jan 10, 2008 | 05:03 PM
brb getting cut
No one?
Old Jan 10, 2008 | 05:06 PM
ttrank's Avatar
Grocery getter
Your answer should be in the interior section. It's hard to ask the sedan guys how to open up a coupe.
Old Jan 10, 2008 | 09:39 PM
oooooooooooooq's Avatar
thats not your interior, IS IT?
Danielek
May 1, 2022 01:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
