NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
- LocationTallahassee, FL (or thereabout)
iTrader Positive Feedback100
iTrader Feedback Score(22)
Liked:852 Times in 640 Posts
Holy crap. I found it.
It's the plastic cap on the very end of the wiper blade itself. The end closest to driver's side A-pillar when installed.
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
Quote:
^Icons.Originally Posted by Mr. G
Which Bosch? The Icons 22" and 18" worked great on mine for years. Trico seem to work fine too.
Also, in the process of removing the end-cap, I discovered something...
A few years ago, before my first set of Icons, I called Bosch and asked if there were "refills" that could be used with them. They told me in no uncertain terms that the entire blade had to be replaced.
Guess what.....
Yeah, you pop the end cap off, and you can slide the rubber blade right out.
Looks like I won't be spending $30 on wipers ever again
Guess what.....
What refills do you replace with?Originally Posted by NFSP G35
^Icons.Also, in the process of removing the end-cap, I discovered something...
Guess what.....
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
^I didn't. I only JUST NOW figured out that was possible.
I am using the goodyear wipers blades from Costco. I have had them for 15 months and at 8 bucks a pop, it has worked well.
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
^My last pair of Icons swiped streak free for two years.
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
Here's the cap:
Once you get it off, the wiper doesn't miss a big spot in the middle any more!
Only problem is it leaves everything kinda loose. I might add some 3m tape inside or something
I don't really care... my wipers work again!!! w000t
AARONHL
close
- Join DateOct 2007
- LocationɷCONNECTICUTɷ
iTrader Feedback Score(15)
Liked:121 Times in 113 Posts
Interesting,
I have also heard (no pun intended) that if your wipers are being noisy (slapping) there is a plastic linkage arm that will need to replaced. Can anyone verify?
