Nismo Exhaust for Sedan
Old Mar 25, 2004 | 10:08 AM
SkyLine350GTs's Avatar
Does anyone know if nismo is going to produce an exhaust system for the sedan.
thanks,
High Point, NC
04 G35 6MT Sedan, Diamond Graphite on Black.
Arrived on 10/20/03
AIM: OneFast4Door G35
Old Mar 25, 2004 | 11:53 AM
Gsedan35's Avatar
Re: Nismo Exhaust for Sedan
They already do. But, their are some catch's
WELDINA CRUISING EXHAUST /ALL STAINLESS
For VQ25DD (2WD), VQ30DD, VQ35DE
Main Pipe Diameter=60-70mm, Tail Pipe Diameter=84x86mm (Square Dual), Divided in 2 Pieces
http://www.japanparts.com/shop/shop....fler%2fExhaust
It's scary expensive once you add shipping. $1,130.00 plus shipping and any fee's, remember you would be paying for shipping from japan to you, and exhaust's are heavy. And that does NOT buy you a new Y-pipe like the Nismo for the Coupe and Z does. When you buy the Stillen or Borla for the sedan, your replacing the Y-pipe in the process. Plus it's pipe diameter specs, while sensibly matching the oem Y-pipe's output, it doesn't match the diameter used for the Coupe and Z system, it's narrower. If you paying that kind of money, the pipe's should be larger, like the Coupe/G Nismo system. But, I'd absolutely love to hear how it sounds (grin). Know, if I had a notion to be different and wanted a Nismo exhaust for the Sedan, I'd buy a coupe Nismo system and use the Y-pipe out of it and the mid pipe (sell it's muffler) then buy the rear Nismo muffler section only for the sedan and pair in all together. Only catch would be the last little bit of pipe for the muffler would be 65mm. But I could likely figure out a way to correct that. It would still be pricey, but you are getting a Y-pipe which is a serious bottle neck on any FM platform car.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Mar 25, 2004 | 12:01 PM
eeewww, nevermind, i heard the nismo on a G coupe, and it was dead sexy, and i just wanted a sound near that. thanks on the info btw.
High Point, NC
Arrived on 10/20/03
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
yoyoyo8
Aug 12, 2015 03:04 AM
avalino
Aug 6, 2015 01:42 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
Kz_Ed
Jul 23, 2015 02:41 AM
