Car Issues Issues Issues
Old Mar 11, 2008 | 08:50 AM
blownvert's Avatar
This car is such a head ache, i dont think I will ever get a infiniti or g35x again. I have a 04. Took it in to service because they finally could duplicate the right rear window sound. It says on receipt - TSB ITB03-071. That is the one when they put felt cloth tape up in the weatherstripping top of window. Well I got the car back and nothing was fixed. Still hear the creak sound going over bumps, rough roads and stop and go something. Now I hear a new noise coming from that same area, it sounds like a wurling metal slightly sound in that same right rear window area all of sudden. Also said i need new front brakes and hardware, car only has 41k miles on it. Brakes go that bad so quick? Do you think I only need pads? Also said my transmission fluid is dirty, so needs to be flushed.
Old Mar 11, 2008 | 09:09 AM
lexusk8's Avatar
Go back to the dealer and tell them you still hear the same problem on the rear window. Make sure they get it fixed for you at no extra charge, and also let the manager of the service dept know about this as well.
As far as the brakes go, yes unfortunately they do go out that quickly in the '03-'04 sedan. I got tired of the dusty stock brake pads on the front, and replaced them with Hawk HPS pads, and it's been low dust and strong braking ever since. If you've never had the tranny fluid drained or flushed, then yes it's definitely time to get it done. The tranny fluid service should be done every 2 years or 30K miles, whichever comes first.
Old Mar 11, 2008 | 11:06 AM
blownvert's Avatar
Yes, i know I will take it back to them. It is such a pain dealing with this and going back and forth. With the brakes, I only need new brake pads right? It says front brakes and hardware.
Old Mar 11, 2008 | 11:38 AM
miltoda's Avatar
This is a little off topic, but how much can one expect to pay to get the tranny flushed at the dealr and/or elsewhere? I've heard there's no dipstick on the transmission so you can't really gauge how dirty the fluid is. Is this true? I've got 33K on my 06 sedan and I'd like my trans to last a while.
Old Mar 11, 2008 | 11:48 AM
Texasscout's Avatar
The thing here guys is to maintain the viability of your warranty. By spending the cash and letting the dealer do it, there is NO QUESTION when it comes to warranty work because THEY DID IT.
This car needs maintaintance, it is NOT a damn Ford Fairlane 500 that you can just throw a can of oil into now and then. You bought an "up market" car, be prepared to pay a little more to take care of it.
I have followed the manufacturers recommendations for service and I have 63K on mine now with NO malfunctions what so ever.
Old Mar 11, 2008 | 12:29 PM
DaveB's Avatar
First thing, are you sure they didn't do the work? The problem with 1st gen G35 is that they cut corners with the interior. It's frustrating, but it's clear they focused on the performance and not so much the interior quality. I have done lots of work with my car quieting rattles and I can tell you that many of the TSB rattles don't come from the areas they're fixing hence the reason people still have the same rattles after the fixes. With the doors, a lot of rattles come from where the plastic panel meets the metal door frame. You'll also notice that rattles are largely dependent on weather/temp/humidity. Check my rattle exocism DIY for some easy fixes.
As for the brakes, you're lucky yours lasted as long as they did. These cars typically require new front pads and rotors every 30K miles. That's the trade off for having exceptional braking and feel. BMW and Benz are the same way. You can save yourself a large sum of money doing this simply job yourself.
For tranny service, the Infiniti recommended first service interval is 60K miles unless you do towing.
Old Mar 11, 2008 | 12:40 PM
5150DS's Avatar
Jsut get a loud exhaust and you won't hear any rattles.
Old Mar 11, 2008 | 12:43 PM
JMAN44544's Avatar
The creak sound in the rear window is the window regulator bolts. There is a recall/bulletin to fix that. They will replace them with different bolts and they will go away. The Bulletin is Infiniti TSB ITB05-034.
Give them that #. Mine drove me nuts and then it was gone after this repair.
Oh and get Hawk HPS pads as your replacements when you do the brakes.
Old Mar 11, 2008 | 12:57 PM
lexusk8's Avatar
Well you almost most likely need new pads but you should also check the rotors. They may be close to the minimum thickness, at which point it's recommended that they get replaced. If you feel any vibration when you apply the brakes when driving, that tells you that your rotors may be warped, at which point the rotors should either get resurfaced or replaced. I recommend full replacement of the rotors, and I also recommend getting a set of Brembo blank rotors which you can find on tirerack.com. These go for roughly the same price as the stock ones, and should last longer and provide better braking performance than the stocks.
I've never done a flush on my transmission fluid as I've done a simple drain and refill which gets rid of 40% of the old fluid. So I don't know how much a flush costs but I'm sure it's no more than 2 bills. In your '06 sedan, you should have a tranny dipstick; it's located behind the middle of the engine, and it's held on by a 10mm bolt. With 33K already in your car, you should probably consider a tranny service soon.
Old Mar 11, 2008 | 01:22 PM
ttrank's Avatar
Grocery getter
41k is a decent amount of time for the oem brakes to last. It's a sports sedan and they tried to make it perform. The problem is the 03/04 rotors are too small so they had to use a very aggressive pad to get the braking they wanted. The pads wear out and eat the rotors quickly.
Old Mar 11, 2008 | 01:23 PM
apintojr's Avatar
on this tranny fluid subject. i have an 05x with 25500 miles. should i consider tranny flush?
Old Mar 11, 2008 | 01:27 PM
ttrank's Avatar
Grocery getter
When I had an auto I always did a drain and refill every 20k or 7th oil change. I think even if you went 30k each time you would be fine.
Old Mar 11, 2008 | 05:00 PM
blownvert's Avatar
problem is i printed that one out and showed him that one. He said it wasnt that one and not the problem. He opened and closed the door numerous times and he said you would hear the bolts rattle or something. I guess mine is not that issue. I dont know i just always hear that dam rattle. Its so annoying.
Old Mar 11, 2008 | 06:41 PM
bkd's Avatar
bkd
Order the bolts and change them yourself. It's only a couple of dollars each side.
Old Mar 11, 2008 | 08:54 PM
miltoda's Avatar
I hear that same sound in my O6. It is so annoying. My 97 corolla had less rattles! My front passenger side window also does it too... but it seems if you slightly roll down the window..it goes away.
