air box mod
Old Jan 1, 2006 | 09:29 PM
  #31
G35_TX's Avatar
Originally Posted by DaveB
And there are 20 more dynos showing nothing. The Stillen airbox is nothing, but a POP style intake with an expensive heat shield.
Really? Where? In controlled conditions too? Strange.
Old Jan 1, 2006 | 09:43 PM
  #32
GEE PASTA's Avatar
Florida G35 Club
Originally Posted by DP03
I would guess there would be ZERO gains with the Stillen after seeing these pics. Our engines bottle neck is probably not the intake, it's more likely exhaust......
There will be dissagreements with my statement, but show me dyno runs and I'll retract my statement. Please, no butt dyno's........
For the most part, I would have to agree with you. My personal opinion is for all of this bolt on mods to work right, The camshaft timing is going to have to be played with. Understanding the VQ has no EGR valve plus with the fact" That for the most part this engine runs on the lean side makes me understand what Nissan is doing for smog. More aggressive cam timing would make all of these bolt on goodies perform better. Its one bad azz motor stock.
Old Jan 1, 2006 | 11:08 PM
  #33
mikeee2's Avatar
Originally Posted by G35_TX
Here are two pics. One stock intake, one with Stillen...
G35_TX,
The Stillen CAI "reuses" the same power duct? I am very close to pulling the trigger for the Stillen CAI just for the sound. What's your impression of the Stillen CAI versus the stock intake sound? I know I've read many saying that it sounds awesome after 3500 rpm, etc but just wanted to get your impressions too. Under 3,000rpm does it sound like the normal intake with k&n or regular filter? I would perfer if the sound kicks in even when it's low rpm (I know...that's usually exahust that does that). Called me weird but I love that drone around 1,500rpm to 2,000rpm. It would be great if the Stillen can increase the drone.
From the picture doesn't seem like you have any clearance issue with the AC line.
How was the installation instructions for the Stillen?
Thanks...
Old Jan 1, 2006 | 11:32 PM
  #34
G35_TX's Avatar
It only uses the powerduct piece with the rubber seal on it. It's a very small piece so it helps guide the air into the intake box. It's normal at wot like stock. But its much louder at WOT. Improvement is pretty much upper rpms only. Lower doesn't change much.
Installation is a breeze. Takes about 30-45 min taking your time. And no clearance issues.
Originally Posted by mikeee2
G35_TX,
Thanks...
Old Jan 1, 2006 | 11:43 PM
  #35
mikeee2's Avatar
From this site.....it seems like it comes with it's own powerduct.
http://www.grubbsperformance.com/Mer...G35SedanIntake
When at WOT above 3,500 etc, when you said it's louder, does it sound "more throaty"?
Old Jan 2, 2006 | 12:28 AM
  #36
DaveB's Avatar
Controlled conditions? Are you expecting me to test in a vacuum or something Test were done over two days during my drive to and from work (20 mile round trip, stop and go traffic and fairly open highway), same conditions to within 5%, same car, same mods, and datalogged. What else is there?
The Stillen Airbox only has one opening. And its towards the front of the car. Other than that it is completely sealed. Per many tests, the Stillen doesn't let engine heat in like other intakes do. See DaveO for the test and temps in one of his tests he has done.
Proven over and over again that there isn't power to gain on a Stillen Intake? Ahhh...where is that data mr. DaveB? There is much more data that proves you otherwise. 2-3 years worth of it.
One opening? Really Tell me where in this pic do you only see one opening?
I see is a huge opening on the driver's side front and side portion of the so-called airbox. If this was truely a sealed box, you wouldn't see the portion of that connects to lower resonator (see the 1" hole at the bottom). All I see is an elaborate heatshield that apparently serves to block some heat on the back side. It is no means an airbox. Clearly you don't own this setup because if you did, you would have seen this.
As for your dyno data, here ya go:
https://g35driver.com/forums/showthr...Stillen+intake
How about for once you post a link showing otherwise. It gets tiresome proving you wrong and then you shooting back with, "well, the information is out there. Do your research."
Old Jan 2, 2006 | 12:05 PM
  #37
G35_TX's Avatar
Wow wait a minute? You owned the Stillen Intake? And you did these tests? Where are they? I'd like to see these results.
I only see one opening and it faces the front of the car where it only gets fresh air, not engine heat. (not including the opening for the powerduct).
Ahhhh this just proves to me you have no clue what your talking about. This intake doesn't connect to the resonator. It connects to the intake tube going across the radiator top. LOL!
Those pictures were mine I posted Dave. I have owned it. I clearly know what I am talking about. Unlike yourself.
You proved yourself wrong. I just pointed out where you were wrong again. Others here know the Stillen CAI gains. They have done the research unlike you. All they have to do is search back about 2 years for the info I think it was where all the intakes were tested together.
Old Jan 2, 2006 | 01:18 PM
  #38
DaveB's Avatar
Russ, are you really going going to sit there and lie to me like this? You say that pic is of YOUR Stillen intake. I must beg the question, when have you EVER owned a silver G35? Your 04 was black as is your 05. Next time when you lie to me, at least don't make it so obvious and blantant.
As for the Stillen intake connecting to the lower resonator, it's amazing how wrong you are. Take a look inside your stock airbox and take note of the 1" ID tube sticking up in the bottom of the airbox. That tube is a resonator. The Stillen airbox clearly attaches to this setup for a base support.
As research, I've done mine. Where's yours?
Old Jan 2, 2006 | 03:06 PM
  #39
G35_TX's Avatar
LOL sad....This proves you don't know what your talking about and have history on this forum.
I can't even stop laughing! You really do research well.
BrianV G35 is black. I bought his Stillen Intake from him. He also drove my car 1 month prior to me buying it.
You just got owned by these pictures.
If I am wrong about the resonator I am sorry. It has been a year since I had a Stillen Intake so I could be wrong. I don't recall it installing into any resonator. So I can say I am definitely wrong or right. But still, its not pulling hot air out of the resonator. It's not open.
You really have done research?! Really? You just proved how much of a idiot you really are Daveb.
Old Jan 2, 2006 | 03:10 PM
  #40
G35_TX's Avatar
Oh and btw. I never lie. It's not in my religion.
Old Jan 2, 2006 | 03:13 PM
  #41
G35_TX's Avatar
https://g35driver.com/forums/showthr...light=2004+g35
When I originally got my G35.
Old Jan 2, 2006 | 06:58 PM
  #42
DaveB's Avatar
My appologies. I did get your prior car confused with Brian's black G. It's a dark day for me getting owned by Russ
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
