Sedan hood latch frozen
Old Mar 17, 2008 | 12:23 PM
harrisot's Avatar
Time to check the oil level but that's kinda hard if you can't open the hood...
The latch under the dashboard does not move enough to release the hood. I can thank a well intentioned idiot for breaking the plastic lever to prove this. Pulling on the newly revealed cable with pliers got me nowhere. I lubed the hell out of the latch by spraying through the grill - but that didn't work. So I dropped the belly pan and tried the secondary release; it is locked up too. From this I surmise that the actual latch is well and truly frozen.
Anybody ever had any success replacing the hood latch with the hood still closed?
Old Mar 21, 2008 | 09:54 AM
harrisot's Avatar
OK, so I'm the only one.
For the record, it would not have been too hard a job to do. The latch is about $45 and the cable is about $75. There are three bolts holding the latch onto the front cross brace and they are not too hard to get to from under the car. The dealer lists this as a 1.5 hour job out the door.
If, like me, your interior trim piece is broken in realizing that your hood doesn't work you can add about $150-$200 to the bill.
Old Mar 21, 2008 | 10:41 AM
bert039's Avatar
How did the plastic lever inside your car break?
Old Mar 21, 2008 | 10:43 AM
chobble19's Avatar
man that sucks! why cant u just unfreeze it?
Old Mar 22, 2008 | 10:25 AM
harrisot's Avatar
The latch wasn't gonna move but that did not deter my "helper" from tugging really, really hard. For $200 I was perfectly content to fabricate a new hood release lever.
Old Mar 22, 2008 | 10:28 AM
harrisot's Avatar
Like you, I woulda thought that soaking it for a couple of days in penetrating oil would do the trick. Turns out it didn't work. I even tried the slim-jim approach reaching through the grill, but to no avail.
Old Mar 23, 2008 | 12:42 PM
Pska's Avatar
park in a heated space for a few hours... goto a mall?
Old Mar 27, 2008 | 12:34 PM
harrisot's Avatar
It lives in a nice, warm garage which is most likely the problem.
In Pittsburgh they are not shy about using salt 7 days a week. Leaving the car in a nice warm spot each night speeds corrosion and probably lead to the lock-up.
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
tiguy99
Mar 1, 2016 11:42 AM
brycealbr
Aug 11, 2015 11:47 AM
