APS Oil pan on G35x
Old Apr 5, 2008 | 12:00 PM
Konsole's Avatar
APS Oil pan on G35x
Does it fit?
Does anyone with an X have an APS oil pan?
The front roll bar is not in the way or anything, and the front driveshaft tube goes through the oil pan (upper) but more to the rear. However the oil filter/cooler assembly is different on the X, it points forward because it uses a different 90 degree filter bracket. There are also some coolant lines on the driver side that are mounted next to the lower oil pan. They may be able to be relocated.
The main thing I am worried about is clearing the water line that comes out of the oil cooler.
Are there any spacers that come with two taps? (I need one for an oil return and one for an oil temp sensor I guess). Do the spacers come with extensions for the pickup tube (because the spacer lowers the oil pan floor)?
Old Apr 5, 2008 | 12:17 PM
DangerMouse's Avatar
Originally Posted by Konsole
Does it fit?
Hi Konsole,
I do not have the APS oil pan on my '04 G35X thanks to the honest folks at Performance Nissan (aka. MyNismo) telling me it would not fit. They said more than one customer with an 'X' returned the oil pan because it interfered with the suspension. I have to think that at that price ($365 USD), they would tell me if there was even the slightest chance.
For what it's worth... if you or someone else does find a quality aftermarket pan that works with the X, please post the details here.
Good luck,
Dan
Old Apr 5, 2008 | 12:31 PM
Konsole's Avatar
Originally Posted by DangerMouse
Hi Konsole,
Good luck,
Dan
Thanks for the info Dan.. i love this forum. I was just under my car and the coolant lines that go into the radiator are in the way but could be moved... however like I suspected the oil cooler line that sticks out the bottom would hit too.
The aps oil pan has a little groove in it to fit around the oil cooler line on a RWD model.
I don't see any suspension stuff in the way, but maybe with enough movement the front sway bar would hit.
OK.. so what spacers would work and let me install an oil temp sensor and oil return line (like for a vortech) ?
Old Apr 5, 2008 | 05:12 PM
ttrank's Avatar
Grocery getter
The only spacer that I know of with holes is the Altered atmosphere one, I have it. The best way for what you are talking about is a sandwich plate adapter. I have the Greddy one which has two ports for whatever you like. I used mine for oil temp and pressure sensors.
Old Apr 5, 2008 | 05:15 PM
ttrank's Avatar
Grocery getter
Here is the spacer. The Forged site says you can use it for sensors too.
http://www.forgedperformance.com/sto...0&cat=0&page=1
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
